Network Management
airwave not displaying SSID
  • 1.  airwave not displaying SSID
    Posted Oct 12, 2015 10:51 AM
    Morning,
    Just curious if anyone has experienced an issue with an Airwave server on 7.7.x code not displaying the SSID associated with client connections. Clients appear to connect and work fine. Dashboard shows all of their info like device type, MAC, etc just no SSID.
  • 2.  RE: airwave not displaying SSID
    Posted Oct 12, 2015 12:19 PM
    What kind of wireless lan controller is this and what version of code?
  • 3.  RE: airwave not displaying SSID
    Posted Oct 13, 2015 02:50 PM
    It's a 7220 on 6.4.2.12 code. It's setup as a local. I have double checked the resources on the Airwave server and there disk space seems to be in good shape as well as the RAM etc..
  • 4.  RE: airwave not displaying SSID
    Posted Oct 13, 2015 02:51 PM
    Forgot to add this. Could this be an MIB issue between the controller and Airwave since they are on an older version of AMP?
  • 5.  RE: airwave not displaying SSID
    Posted Oct 13, 2015 03:52 PM
    It is entirely possible.  Upgrade to 8.x...
  • 6.  RE: airwave not displaying SSID
    Posted Oct 26, 2015 11:52 AM
    THanks, That was the solution. 7.7.4 is not compatible with 6.4.x
