Network Management
last person joined: 3 hours ago
  • 1.  airwave
    Posted Jun 24, 2015 05:49 AM
    I've actually just installed airwave software (iso file) on the ESXi server, but i'm not able to acceed to the airwave through the browser . Need some help.
    Thanks in advance.
  • 2.  RE: airwave
    Posted Jun 24, 2015 07:27 AM
    Is it actually connected to the network successfully? Can you ping the device?
    If you can, are you then able to ssh into the box? If you are able to connect on SSH try to login with the root account and password you setup.
    You can check if the processes are running correctly by running:
    # wd
    Paste that here, or look for the httpd service running
    _ELiasz
  • 3.  RE: airwave
    Posted Jun 24, 2015 07:34 AM
    Thank you for you reply. Well,Yes i can ping the device, and i have access to it via ssh and also when i write wd the process is running correctly , but i can't have access via browser.
    Best Regards,
    kadi
  • 4.  RE: airwave
    Posted Jun 24, 2015 08:19 AM
    Are you using https:// from the browser? Although mine redirects from http to https.
    Do you have telnet installed? Try to see if you can telnet to port 443 of AMP from your desktop and see if it responds? If you don't have telnet installed, open up putty, set it to telnet and put in port 443.
    Is there any firewall between AMP and where you are trying to access it from?
  • 5.  RE: airwave
    Posted Jun 24, 2015 08:27 AM
    Yes i tried both https and http on the browser but not working and i can't have telnet access either (this is puty's message network error: connection refused)
  • 6.  RE: airwave
    Posted Jun 24, 2015 08:28 AM
    Hello Eliasz,
  • 7.  RE: airwave
    Posted Jun 24, 2015 09:21 AM
    Kadi,
    Are you sure you do not have a duplicate address?  If you do an ifconfig on the shell, do you see the correct ip address?
  • 8.  RE: airwave
    Posted Jun 24, 2015 09:57 AM
    I solved the problem, actually , i tried to acceed via the browser , by taping http:// (my ip add):8080 , so it works.
    Thanks for your feedback.
