@DariusTheGreat wrote:
How can I display all my APs seen by my controller at once. The command is >show ap database ( database-summary). But this gives me just few at the time. i need them all so I can copy and paste it to a spreadsheet.
Ray
On the commandline, if you type "config t no paging" and then enter, it will give you output with no page breaks..
EDIT: Just "no paging" in enable mode should work.
