Network Management
s1500 switch configuration
We have one s1500 48 port switch no working in Erbil-Parkview apartmen the Wifi internet coincidentally was no working, when i check the switch the fiber optic feeding cable is normal but the software program was removed .
Please can you explain why the spftware removed
Eng.Muhammad Tahseen
Irak-Erbil
Tel.00964 750 445 9607
Re: s1500 switch configuration
Who manages those switches?
The subcontractor for Parkview project is ILCI Holding its Turkish company, her we have 60 switch now the the project is finish and system is working only one switch the software was remove. can you help me
Eng.Muhammed
Maintenance Manager
PPMC ( PREMIER PROPERTY MANAGEMENT COMPANY)
ERBIL-IRAQ
Do you know what version the other switches have?  Please PM me your email address and I will send it to you for the S1500.
please where i can check the version at other switches have.
My Email : muhammad.tahseen@ppmc.co
SSH into that switch and type "show version"
Name:Aruba Operating System Software.
Model:ArubaS1500-48P
Version:7.2.2.0
Compiled:2013-04-30 at 09:46:46 PDT (build 38210) by p4build
WebSite:http://www.arubanetworks.com
