Network Management
server specs for air Wave?
  • 1.  server specs for air Wave?
    Posted Aug 23, 2016 11:04 AM
    looking for a little informaion, I'm trying to build a Server to hold Airwave on but can not seem to find info and spaecs for Server requirments, ie Hardware and what not. anyone out there know?
    James
  • 2.  RE: server specs for air Wave?
    Posted Aug 23, 2016 11:12 AM
  • 3.  RE: server specs for air Wave?
    Posted Aug 23, 2016 11:34 AM
    Hello
    I was using that and i got a question for you
    For the client per AP it take as baseline 5 clients? really? just 5 clients??
    I mean if i put 10 clients per AP that considered as high client count per ap??
    so just putting 10 clients per ap that will double all my requirements???
    i mean i just put 10 AP that are being monitored and 10 clients per ap , using AMON and high mobility.
    this is the recommendation:
    Your AirWave server recommended sizing:
    * Recommended CPU PassMark score is 10602
    * Recommended memory is 13GB
    * Recommended disk IOPS capacity is 3333
    * Recommended disk space is 275GB
    Really 13 GB ram ???
    I just find this odd... :/
    Cheers
    Carlos
