Network Management
upgrade controllers network wide process
  • 1.  upgrade controllers network wide process
    Posted Feb 21, 2017 06:05 PM
    Our network consists of master switch stack of 2 7210 controllers for redundancy. These manage centralise licensing
    We then have over 100 Controllers at seperate sites that all talk to teh Master.
    We are currently running 6.4.2.6
    we wish to upgrade all contrlooers, totake advantage of teh Clarity component.
    What sequence should i upgrade my controllers
    Once I upgrade a controller, it no longer commenicates with the master as the OS dont talk to each other.
    Do I
    1. switch master over to standby
    2. upgrade primary master
    3. stage upgrades to remote controllers
    4. cut back to primary master
    5. upgrade standby master
    What sort of user outage can I expect, if any
    Is the sequence above sort of ok
  • 2.  RE: upgrade controllers network wide process
    Posted Feb 21, 2017 07:17 PM
    Which version of ArubaOS are you upgrading to?
    Have you already run Clarity in your lab?
    Have you staged the upgrade in your lab?
  • 3.  RE: upgrade controllers network wide process
    Posted Feb 21, 2017 07:29 PM
    I think it is 6.4.3
    Short test on one controler which gave us clarity visibility on Airwave 8.2.2.1
    Have not staged any upgrade in lab yet as I am putting together the sequence and proposed staging process, before lab testing
  • 4.  RE: upgrade controllers network wide process
    Posted Feb 21, 2017 07:43 PM
    It is not easy to tell you how to upgrade 100 controllers on a forum.  I would possibly speak to your local Aruba Sales Engineer to get ideas specific to your deployment.  That person would be able to guide you past any pitfalls or gotchas.  In a perfect world, I would first upgrade the master and backup master at the same time, and then upgrade the rest, but this is not a perfect world.
