6.1.2.7 upgrade issues
  • 1.  6.1.2.7 upgrade issues
    Posted Mar 02, 2012 02:10 PM
    We updated to 6.1.2.7 and seem to be having an issue with Firefox not loading the login page for our guest network.
    Chrome & IE seem to work OK.
    Even though it will not bring up the login page I can still ping out and get an IP address. I just cannot load any web pages and never get the page for authenication.
  • 2.  RE: 6.1.2.7 upgrade issues
    Posted Mar 02, 2012 02:34 PM
    Sounds like OCSP problems.  Try turning off OCSP on your browser and see if it works.
    You can allow the OCSP IP address through the pre-login role and that should resolve the issue as well.
    Search Airheads for OCSP and you will find more info.
  • 3.  RE: 6.1.2.7 upgrade issues
    Posted Mar 02, 2012 02:52 PM
    Thank you that worked great, I wish we didn't have to disable a security feature like that but it was necessary.
  • 4.  RE: 6.1.2.7 upgrade issues
    Posted Mar 02, 2012 03:28 PM
    You can always add ACLs to the pre-login role that allow http to the OCSP provider(s).  That way, you don't have to disable OCSP completely.
    Glad it's working better.
