802.1x wired recommendations
This thread has been viewed 19 times
  • 1.  802.1x wired recommendations
    Posted Feb 23, 2015 01:42 PM
    Im setting up 802.1x for wirless and wired. Here are the requirements:
    Employee SSID: Domain credentials and Machine account = yes = allow on the network
    BYOD = check endpoint repository if mac = Known = allow on the network
    Here is what I setup for that, its working but need confirmation it looks good and that machine authenticated is setup correctly:
    I pretty much want to do the same thing for wired. Can I setup the above with a 802.1x wired service? Any Gotchas or recommendations? How are Vlans assigned? In a wired scenario, is it common to require all windows devices to have dot1x enabled (Wired Autoconfig)? If enabling wired autoconfig, will that cfause issues when they take their laptops to outside networks not requiring 802.1x.
    Wired and wirelss 802.1x, is there a specific order they need to be in?
  • 2.  RE: 802.1x wired recommendations
    Posted Feb 23, 2015 01:48 PM
    What switch are you using ?
  • 3.  RE: 802.1x wired recommendations
    Posted Feb 23, 2015 03:28 PM
    Cisco switches. We have already implemented aruba cisco switch 802 settings.
  • 4.  RE: 802.1x wired recommendations
    Posted Feb 23, 2015 03:48 PM
    In terms of implementation it should be similar to Aruba switch but instead of returning an Aruba role or VLAN , just create a VLAN enforcement profile and then add the VLAN you would like to test.
    If you want to allow non-802.1x devices to authenticate you can use Cisco MAB Or use fail open VLAN
  • 5.  RE: 802.1x wired recommendations
    Posted Feb 23, 2015 03:49 PM
    Hi Kong_Down,
    Here's a list of some of your questions:
    1. Will enabling 802.1X on the wired cause an issue when they're not in the office.
    No, if it's configured correctly. Make sure that "Fallback to unauthorized network access" is checked under the Authentication tab for the wired interface. If not, then yes, it will cause an issue.
    2. Sending VLANs on a Cisco
    Go to Configuration > Enforcement > Profiles > Add > Template > VLAN Enforcement
    The Tunnel-Private-Group-Id will be the VLAN the user will receive on a switch. You can also send a VLAN ID / name on a Cisco switch to scale the solution.
    Hope it helps!
    -Mike
  • 6.  RE: 802.1x wired recommendations
    Posted Feb 25, 2015 12:43 PM
    Hey guys, I was successful on the VLAN template for 802.1x wired users but not the non-802.1x users. My plan was to enable enpoint repository as authenticator and if the MAC = Known then allow. That doesnt seem to work. Not sure what MAB is. Instructions or recommendations? thxs much
  • 7.  RE: 802.1x wired recommendations
    Posted Feb 25, 2015 12:45 PM
    Are you seeing requests come in?
    Do you have "Allow All MAC Auth" as your authnetication method?
  • 8.  RE: 802.1x wired recommendations
    Posted Feb 25, 2015 01:21 PM
    You will need MAB configured on the cisco switch .
    MAB is Mac Auth Bypass and allows you to authenticate users when 802.1x fails then it will do Mac authentication , you can define the order in the interface :
    interface <INTERFACE-NAME>
    switchport mode access
    authentication event no-response action authorize vlan <GUEST-VLANID>
    authentication order dot1x mab
    authentication priority dot1x mab
    authentication port-control auto
    authentication periodic
    authentication timer reauthenticate server
    mab
    spanning-tree portfast
  • 9.  RE: 802.1x wired recommendations
    Posted Feb 25, 2015 03:02 PM
    So MAB setting are all setup correctly. Im finally seeing logs. Again, 802.1x works fine. Its the non-802.1x clients im trying to configure. The non-802.1x client failed attempts are showing as "Failed to classify service" see my attached setting. Let me know what I need to change. Thsi service is ahndling both 802.1x and non-802.1x request on wired. Maybe I need to setup a seperate non-802.1x service?
  • 10.  RE: 802.1x wired recommendations
    Posted Feb 25, 2015 03:03 PM
    You need two different services. One for MAC-auth and one for 802.1X.
  • 11.  RE: 802.1x wired recommendations
    Posted Feb 25, 2015 03:17 PM
    Can you provide instruction on setting this up for wired mac auth non 802.1x please
    Jeremy Rouse
    Technical Specialist II, Bird Rock Systems, Inc.
    Phone: (858) 346-1384
    "We Build Rock Solid Solutions"
    www.birdrockusa.com
  • 12.  RE: 802.1x wired recommendations
    Posted Feb 25, 2015 03:19 PM
    There is a device MAC authentication service template
    Have you considered working with an Aruba partner?
  • 13.  RE: 802.1x wired recommendations
    Posted Feb 25, 2015 03:36 PM
    What I am trying to do, Im guessing is fairly easy for CPPM experts. MAC device template wont work. I have collected all my MAC addresses in the endpoint repository. I have set the authorzed ones to known. It works for wireless. I need to get it to work for wired. basically, user plugs non-802.1x computer/printer/etc into a wired port, it calles CPPM for MAC authentication/authorization and checks the end user repository for MAC equals Known and allows on the network. Any instuctions are helpful - please
  • 14.  RE: 802.1x wired recommendations
    Posted Feb 25, 2015 04:21 PM
    Like cappalli suggested you just need to create a new MAC AUTH template and then add the Endpoint DB as an authorization source and finally add in your logic that if the device status is known to assign the VLAN enforcement profile
  • 15.  RE: 802.1x wired recommendations
    Posted Feb 25, 2015 05:03 PM
    Thanks. I figured out that mac auth is not difficult. The issue appears I'm not seeing request hit cppm. I'm thinking it's the 2960 switch. I have the mab setup per your recommendations but still no joy.
  • 16.  RE: 802.1x wired recommendations
    Posted Feb 25, 2015 05:05 PM
    Please export and attach the access tracker request.
    Tim
  • 17.  RE: 802.1x wired recommendations
    Posted Mar 02, 2015 02:02 PM
    See attached. Again the 802.1x wired works. MAB does not. Looks like MAB requests are getting denied by 802.1x responses. Do I need to create a seperate service for the non-802.1x requests?
    Attachment(s)
    txt
    Dashboard_Details.txt   2 KB 1 version
  • 18.  RE: 802.1x wired recommendations
    Posted Mar 02, 2015 02:03 PM
    Attachment(s)
    txt
    Request_Logs.txt   15 KB 1 version
  • 19.  RE: 802.1x wired recommendations
    Posted Mar 02, 2015 02:35 PM
    attached - thxs
  • 20.  RE: 802.1x wired recommendations
    Posted Mar 02, 2015 04:36 PM
    Kong_Down,
    Click on "Reorder" to move your mac authentication service to the top.  It looks like your mac authentication is hitting your 802.1x service.  Your mac authentication service is more specific and needs to be at the top to check to make sure the "connection client mac address = username".
  • 21.  RE: 802.1x wired recommendations
    Posted Mar 05, 2015 02:10 PM
    this is resolved thxs
  • 22.  RE: 802.1x wired recommendations
    Posted Mar 02, 2015 02:12 PM
    Do you have a MAC-auth service? Can you post a screenshot of it?
