Aruba 7010 controller - ArubaOS version that came with the device
3 - AP 205's
1 - Comcast cable modem
Trying to setup just a quick, easy, no captive portal, guest wifi.
Cable Modem connected to Port 14 - IP is 10.1.10.1
Port 1,2,3 connected to 3 AP 205's
Plugged everything into the Aruba controller, booted it up. Had a laptop connected to port 13 for the initial setup. Laptop received the dhcp lease from the controller just fine. Going through the initial setup wizard, I setup the following:
Controller IP - 10.1.5.254 (VLAN 100 Interface)
VLAN 100 - 10.1.5.254 Interface IP (DHCP Server enabled - 10.1.5.0/24, default gateway 10.1.5.254)
VLAN 200 - 10.1.10.11 Interface IP
No captive portal, guest have direct access to internet
Default Route is 10.1.10.1 (Cable Modem connected to port 14)
All Ports trusted
Inter VLAN routing is enabled.
All 3 access points find the controller and are provisioned with the default profile (Guest-WiFi SSID)
I tried with both android, and apple devices. I can get them to connect to the access points just fine. They get the DHCP ip's from the controller (10.1.5.0/24 network), but cannot get any access outside of the Aruba controller.
Using SSH - I can remote into the Aruba controller and ping the cable modem (10.1.10.1). I can do a trace route to an external IP 75.75.75.75 and it works. DNS resolution works from the controller as well.
Doing a ping from a client connected to an AP, i can ping the internal interface (10.1.5.254) and I can ping the external interface (10.1.10.11). But I can't ping anything past that.
I am stumped, as far as I can tell it should work, but the Aruba controller is not routing traffic from VLAN 100 to VLAN 200... What am I missing?
Thanks!
Chris
#AP205
