AAA Authentication (TACACS+) for Citrix Netscalers
Hello Team,
I was looking for some additional detail related to the AAA TACACS configuration for some citrix Netscaler devices that i want to move off a previous ACS 5.3 deployment. I noticed that citrix is not an available vendor for adding "devices" in the Aruba clearpass 6.3 engine.
My question; can we import citrix as a vendor? If so, how would one go about adding a new vendor to that list? This would be used at the beginning to authenticate the user group just to access the nodes. We would wrap more granular control once I have the individual command sets ported into the system.
Thanks in advance, looking forward to the responses and/or suggestions.
Re: AAA Authentication (TACACS+) for Citrix Netscalers
Try adding it as an IETF device.  You can create a NetScaler Device Group which can be used in policy elsewhere.
Seth R. Fiermonti
Consulting Systems Engineer - ACCX, ACDX, ACMX
If you found my post helpful, please give kudos
