AD integration with Aruba Controller
This thread has been viewed 31 times
  • 1.  AD integration with Aruba Controller
    Posted May 08, 2016 11:37 AM
    Hi All,
    I have aruba 7210 controllers running on aos 6.4.3.5. Is there any way to integrate Active Directory with the aruba Controllers except through RADIUS method?
    If yes , what would be the configuration on Controllers side?
    Regards
    Sachin
  • 2.  RE: AD integration with Aruba Controller
    Posted May 08, 2016 11:40 AM
    It's recommended to use a RADIUS server, but LDAP can be used with certain restrictions.
    http://community.arubanetworks.com/t5/Controller-Based-WLANs/How-do-I-configure-LDAP-on-the-Aruba-controller/ta-p/184056
  • 3.  RE: AD integration with Aruba Controller
    Posted May 08, 2016 12:35 PM
    @Sachin wrote:
    Hi All,
    Regards
    Sachin
    LDAP is fine if you are only authenticating AD users via captive portal.  If you are using 802.1x, LDAP has too many client restrictions to deploy at scale.
  • 4.  RE: AD integration with Aruba Controller
    Posted Nov 16, 2018 07:04 AM
    hello Tim and Joseph,
    curious to know what kind of restriction users may face, please could you provide some details for visibility.
    Thank you !
  • 5.  RE: AD integration with Aruba Controller
    Posted Nov 16, 2018 08:51 AM
    I don't understand.  This thread is also two years old.
  • 6.  RE: AD integration with Aruba Controller
    Posted Nov 19, 2018 07:24 AM
    Hello Joseph,
    sorry for not being more specific,
    I'm thinking about an integration of Aruba controller with Windows AD, and I noticed in your contribution that it feasible but LDAP had too many restrictions for users.
    so I would like to know what kind of restriction we may face?
    thank you!
  • 7.  RE: AD integration with Aruba Controller
    Posted Nov 22, 2018 12:45 PM
    Any feedback here?
    thank you!
  • 8.  RE: AD integration with Aruba Controller
    Posted Nov 22, 2018 12:54 PM
    You have to install additonal software on Windows clients if you use LDAP instead of radius.  Nobody does that.
