Add interface description in Clearpass
  • 1.  Add interface description in Clearpass
    Posted Apr 07, 2017 04:20 AM
    Has anyone expierence with adding Interface description from Cisco within the clearpass manager? We are using the cisco description for location information of the walloutlet.
  • 2.  RE: Add interface description in Clearpass
    Posted Apr 07, 2017 06:15 AM
    Adding them to what?
  • 3.  RE: Add interface description in Clearpass
  • 4.  RE: Add interface description in Clearpass
    Posted Apr 07, 2017 07:08 AM
    Adding to the Endpoint repository within Clearpass manager.
  • 5.  RE: Add interface description in Clearpass
    Posted Apr 07, 2017 07:16 AM
    No, it's locally significant in the config and the switch does not pass it in the RADIUS request so we never see it on the ClearPass side.
  • 6.  RE: Add interface description in Clearpass
  • 7.  RE: Add interface description in Clearpass
    Posted Apr 07, 2017 07:34 AM
    ok, thank you.
    is there another option availabe to load this information within clearpass through in import anywhere or fill clearpass with this information by the API?
  • 8.  RE: Add interface description in Clearpass
    Posted Apr 07, 2017 07:41 AM
    Sure, you could use the API. Not sure I’m following what the use case is.
  • 9.  RE: Add interface description in Clearpass
    Posted Apr 07, 2017 07:51 AM
    i want to have the overview of switchport and description within one field in clearpass. it is easy for our helpdesk to support users if they also could see the description, because our description describes the physically wallout. if an enduser call the helpdesk and tell the outlet as information, they are able to see all information within one screen, instead of logging also in on the cisco switch to check what the outlet number is.
  • 10.  RE: Add interface description in Clearpass
    Posted Apr 07, 2017 08:00 AM
    Won’t the information easily go stale after a change on the switch?
    We generally don't recommend writing dynamic data to a static field. But if this meets your use case, you can absolutely use the REST API to populate that data.
  • 11.  RE: Add interface description in Clearpass
