Frequent Contributor II
After configuring the clearpass with cisco switch for MAC and 802.1x I got port error disable?
I have a problem showedd up after ocnfiguring teh global configs and port config on cisco switch and connected Cisco IP phone and Computer connected from Ip-Phone and port go error disable and configs as below:
switchport mode access
 switchport access vlan 1
 authentication order dot1x mab
 authentication priority dot1x mab
 authentication port-control auto
 authentication periodic
 authentication timer reauthenticate server
 mab
 dot1x pae authenticator
 dot1x timeout server-timeout 30
 dot1x timeout tx-period 30
 dot1x timeout supp-timeout 30
 dot1x max-req 3
 dot1x max-reauth-req 10
 spanning-tree portfast
Re: After configuring the clearpass with cisco switch for MAC and 802.1x I got port error disable?
What does the err-disable log say?
Tim Cappalli | Aruba Security
Actually I couldnt see it so what is teh command that I can run?
show interface status err-disabled
Switch#show interfaces status err-disabled
Port      Name               Status       Reason               Err-disabled Vlans
Gi1/0/12  *** Connected To A err-disabled security-violation
Switch#
I figured it out it was issue because of host mode I used this configuration below but the thing is I didnt see any mac request from IP Phone and it work normally:
 switchport voice vlan 22
 authentication host-mode multi-host
 mab
 mls qos trust device cisco-phone
 dot1x timeout tx-period 10
 dot1x max-req 3
 storm-control broadcast level 30.00
 spanning-tree bpduguard enable
