Contributor I
Afterwards Web Authentication Disabled
Hi
There were some threads about “Web Authentication Disabled” a year ago. Does anyone confirm it was fixed in any version? It was on 6.1.3.1 release note as known issue, so I thought it was not fixed yet. But it's NOT appeared on 6.1.3.2 release note neither known issue nor fixed one. So I am wondering if it is fixed or not. Also, we encounters “Web Authentication Disabled” on 5.0.3.3. Is it fixed on 5.x as well?
Regards
Simon
Re: Afterwards Web Authentication Disabled
It should be fixed in 6.1.3.2.
Contributor I
thanks, cjoseph
So it soulds like it is not fixed in 5.0.4.7..
I will ask to migrate it into 5.0.x by SR open.
Regards
Simon
I do not see it as an existing issue in the release notes or a fixed one in 5.0.x.
