AirGroup Location Issue
Hi All,
I've configured a controller and CPPM to support AirGroup. It's working across VLAN, SSIDs etc..
I'm testing out the location aspect of AirGroup but this doesn't appear to be working on the controller.
I've enabled AirGroup location on the controller.
On CPPM I've specified an AP location.
In the access tracker when I see the Apple TV authenticate it's showing the AirGroup details..
Clients associated to the "AP-MAX-3000" AP are not showing as near this AirGroup server though..
Any ideas why?
Cheers
James
Cheers
James
Re: AirGroup Location Issue
Did you type in the AP location manually, or did you use ClearPass to select the AP from a dropdown?
I configured Clearpass so I could select the AP location (ap name) from a drop down list.
Cheers
James
