Hi:
I've configured Airgroup to share Apple TV's across subnets. I then wanted to configure Clearpass Guest to help restrict device sharing. I entered Clearpass info in the controller's Airplay setings, and I've setup the controller in Clearpass Guest --> Airgroup Services --> Controllers. Clearpass can successfully read the controller's config.
I then added my Airplay server as a device and enabled Airgroup sharing.
The problem is that when I login to the network on my iPad, I can see the AppleTV no matter what I do. I've tried restricting it to a user or location that's not in use, but it still shows up on the iPad.
Could I be looking at a cache issue? I've issued many 'aaa user delete' commands. I've also tried 'airgroup server-refresh'. Is there anything else that needs to be done after changing airgroup device sharing in Clearpass?
I see lots of access requests in Access Tracker being handled by the [AirGroup Authorization Service]. Is this default service all I need, or do I need to define a custom service?
Any other ideas on troubleshooting?
Thank You!
