Greetings,
I am configuring a new template and want to set the avaiable bandwidth for an SSID.
I had hoped to use custom variables similar to
%if custom_variable_4%
bandwidth-limit %custom_variable_4%
%endif%
What i would like to do is use an "Elseif" after the bandwidth-limit command to set the default when custom_variable-4 isnt present.
I have tried
%elseif%
bandwidth-limit 1024
%endif%
When I push the config to the AP/VC and audit it, it fails.
Is there a command similar to "else" that will allow me to apply a default if the chosen variable is empty?
TIA
G
