Contributor I
Android PIN enforcement
Android Devices are getting promted to setup an PIN Code for the lock screen while OnBoarding. We would like to disable this check.
Is it possible to disable the "lockscreen PIN enforcement"?
Re: Android PIN enforcement
That PIN requirement (or more precise, a lock-screen requirement) is enforced by Android.
Check here:
.. and you can see some hacks with root access to get around it, where in most cases it doesn't work for all devices.
In short: Google has made it mandatory to put protection on your device before you can install client certificates (and the certificates are removed in most cases if you disable it again). No (good) way to disable that requirement.
Contributor I
Thanks for the informations.
