AppRF Not Functioning
I have a Controller 7005 with the latest firmware version 6.4.2.3. I'm trying to configure AppRF to block Youtube or Facebook, it seems like not running. I have already make sure AppRF is enabled, applied the AppRF rules into the right role. But still, I'm able to access youtube and facebook. Anyone encounter such an issue?
Re: AppRF Not Functioning
Do you have dns lookups enabled and Dns servers defined?
Tim
Tim Cappalli | Aruba Security
Aruba
Make sure:
1) Deep Packet Inspection is enabled under stateful firewall (per controller)
2) Deep Packet Inspection is enabled on the user role in question
2) DNS lookups are enabled on the controller
AMFX | ACCX | ACDX | ACMX
Where do I enable DNS lookup in the controller?
Sent from Mike iPhone
ip domain lookup
ip domain-name <domain name>
ip name-server <DNS-IP-1>
ip name-server <DNS-IP-2>
I have enabled the IP domain lookup already.
But still not able to block youtube.
Anything else I need to take note?
Trusted Contributor I
have you checked if DNS works? done a DNS lookup from the controller?
I have solved the issue. Thanks for the advise.
