We have AppLocker configured to allow ArubaQuickConnect.exe based on digital certificate, but on some random copputers (around 30), AppLocker is not able to extract that info from the file and won't let it run. Those computers are able to identify other regular exe files, like Microsoft ones.
Which version of quickconnect.exe is this? Are you using it to push credentials for onboarding or to just configure SSIDs on devices?
What specific OS's is it different on (to help us narrow down what you are seeing)?
Actually I'm with OS team and not MDM, but as far as I know, it's for certificates for home users.
ClearPass QuickConnect
Version is: 0.0.0.10000
User devices are Win 8.1 x64. it also failed on mine: Win 10 x64.
Your colleagues who configure the ClearPass server should open a TAC case for this, since support will have additional questions for them, that you might not be able to answer specifically.
Thanks Tim! That seems to be the issue. Test PC was missing the cert, just added the cert to the test computer and it's detecting the publisher. Will do further testing tomorrow, but looks like it's been resolved!
Thanks again for your quick hint!
