Aruba WLAN controller RADIUS VSA for non-administrative (read-only) access
  • 1.  Aruba WLAN controller RADIUS VSA for non-administrative (read-only) access
    Posted Jul 06, 2015 02:04 PM
    We want to use Windows server 2012 NPS RADIUS for both read-write management access and read-only management access and we have configured an Aruba 3200 controller to point to the radius server and Windows Active directory groups for differentiating administrative access from non-administrative or read-only access.
    I log in with my normal account (dbell) with putty (SSH) and I get limited > access. I can then login with my Privileged AD account (dbell-pr) and gain admin privileged access.  On the web gui I log in with my dbell-pr and get admin access and if I log in with my normal dbell account I still get privileged access (admin).  Do you have any ideas on how to eliminate administrative access through the web gui for my normal non-privileged account?  We are using 14823 as directed by limited documentation we have found.  We are currently using a 1 for the vendor assigned attribute number and it works to limit access through putty to only read-only, but does nothing to limit read-write access on the web GUI.  Am I missing something here?
  • 2.  RE: Aruba WLAN controller RADIUS VSA for non-administrative (read-only) access
    Posted Jul 06, 2015 02:14 PM
    You should make sure that on the Aruba controller the default role for administrative access is set to "no access". That way, only someone who has the administrative VSA of root will get root.
  • 3.  RE: Aruba WLAN controller RADIUS VSA for non-administrative (read-only) access
    Posted Jul 07, 2015 08:17 AM
    Doing this will completly lock you out of managing the controller.
  • 4.  RE: Aruba WLAN controller RADIUS VSA for non-administrative (read-only) access
    Posted Jul 07, 2015 08:19 AM
    No, If local authentication is enabled you can still log in using your root credential.
  • 5.  RE: Aruba WLAN controller RADIUS VSA for non-administrative (read-only) access
    Posted Jul 07, 2015 08:20 AM
    No you are wrong> Try it
  • 6.  RE: Aruba WLAN controller RADIUS VSA for non-administrative (read-only) access
    Posted Jul 07, 2015 08:27 AM
    if "no access" is enabled, local authentication will not work unless the radius server is not responding at which point local access will work again.
  • 7.  RE: Aruba WLAN controller RADIUS VSA for non-administrative (read-only) access
    Posted Jul 07, 2015 08:33 AM
    pmonardo,
    "No Access" means do not allow access to anyone who does not send a Administrative Role in the Aruba VSA during Authentication.  Which means that people that simply pass authentication in Radius, cannot access the controller.
    If you uncheck "Allow Local Authentication", local users cannot authenticate, when radius is still responding.
    Combining both means only a user who authenticates successfully via radius and his user sends a VSA will be able to access the controller, when the radius server is reachable.  If the radius server is not reachable, local admin accounts will work with both of these options enabled.
    I just want to make it clear those two options are different things.
  • 8.  RE: Aruba WLAN controller RADIUS VSA for non-administrative (read-only) access
    Posted Jul 07, 2015 08:39 AM
    Yes my mistake. Thanks for clearing that up Cjoseph. I was thinking about "Allow local authentication".
  • 9.  RE: Aruba WLAN controller RADIUS VSA for non-administrative (read-only) access
    Posted Jul 14, 2015 08:40 AM
    We finally have RADIUS working the way we anticipated it would. Most of our issues were with the Windows NPS server. We created two policies - one with the Aruba Vendor Specific Attributes and using a 3 (#show aaa radius-attributes) to return Administrative access.  The read-only that had alluded us was configured with the help of Aruba Technical Support - we created a standard policy to match the string readonly. On the Aruba 3200 controller under MANAGEMENT>ADMINISTRATION we (as was wisely pointed out here) we checked Allow Local Authentication to retain administrative access when RADIUS was not available. We pointed to our previously configured RADIUS server group and then added a server rule. The rule used the attribute "class" to match our Windows Server 2012 policy that we had created with the "class" attribute. with the operation >" equals" and our operand "readonly" Tyoe "string"  with action "set role" and value "network-operations"   I also had to go back after looking at "show logginsessions" on the controller and seeing that my administrative role had changes due to changing the Default role on the configuration for management to read-only. I changed this back to root and then my role for administrative access worked again.  So now we have a Windows AD group that;s members have only read-only access and another Windows AD group that has read-write access. This is to satisfy our two teams one being a security team that needs read-only nad another team that has read-write access for network operation.  I really appreciate the help here and I understand that sometimes the solutions need a little bit of teamwork to resolve
  • 10.  RE: Aruba WLAN controller RADIUS VSA for non-administrative (read-only) access
    Posted Jul 07, 2015 08:52 AM
    I disconnected from the network and have a controlable controller once again.
    Still do not have a solution for read-only access for network auditors.  Will have to point them at AMP I guess?
  • 11.  RE: Aruba WLAN controller RADIUS VSA for non-administrative (read-only) access
    Posted Jul 07, 2015 09:01 AM
    dbell6809,
    For your network auditors you would return the attribute of "read-only" to give them read only access from radius.  Your returned attribute has to match an administrative role exactly for users to gain access:
    If you had to disconnect from the network, you have "allow local authentication" unchecked.  You will need to correctly be sending back that radius attribute from the document as either "root" or "read-only" to give users access when "no access" is enabled.  If you have anything besides "no access" enabled, any user who simply passes radius authentication has access to your controller and that is not a good thing.
  • 12.  RE: Aruba WLAN controller RADIUS VSA for non-administrative (read-only) access
    Posted Jul 07, 2015 09:05 AM
    We are trying to get that to work but have not found the correct VSA
    attribute to return read-only for the Web GUI. Our configuration works
    correctly for putty or SSH access but not the gui.
    *Dennis Bell*
    *Senior Network Engineer*
    *Stinger Ghaffarian Technologies (SGT)*
    *Contractor to U.S. Geological Survey (USGS)*
    *Earth Resources Observation and Science Center (EROS)*
    *47914 252nd Street*
    *Sioux Falls, SD 57198-0001*
    *(605)594-6809*
  • 13.  RE: Aruba WLAN controller RADIUS VSA for non-administrative (read-only) access
    Posted Jul 07, 2015 09:16 AM
    Did you read the document from the post that I linked to here?  http://community.arubanetworks.com/t5/Monitoring-Management-Location/Management-Authentication-using-Windows-2008-as-a-Radius-Server/ta-p/174672
    There is an attached document that details how to do this.
  • 14.  RE: Aruba WLAN controller RADIUS VSA for non-administrative (read-only) access
    Posted Jul 07, 2015 09:22 AM
    The same administrative rights should work on both GUI and SSH.
  • 15.  RE: Aruba WLAN controller RADIUS VSA for non-administrative (read-only) access
    Posted Jul 07, 2015 09:29 AM
    You certainly would think so. They however do not. Like I said putty works
    fine but the GUI allows full administrative access using the non-privileged
    user account. I would have expected putty to work the same way. I guess I
    should go back in with putty and if although I have pound prompt, I may
    not be able to make changes.
    *Dennis Bell*
    *(605)594-6809*
  • 16.  RE: Aruba WLAN controller RADIUS VSA for non-administrative (read-only) access
    Posted Jul 07, 2015 09:33 AM
    Type show loginsessions to see what role admin users get.
  • 17.  RE: Aruba WLAN controller RADIUS VSA for non-administrative (read-only) access
    Posted Jul 07, 2015 09:43 AM
    So in the first example you see me logged in with my normal non-privileged
    account. Then I logged in with my pr account and connected and I could run
    the command and the sh loginsessions shows that with my non-privileged
    account I am also logged in as root, but If you look you will see that with
    dbell I have the greater then sign and can't make changes exactly the way
    it is supposed to work although it is displaying it incorrectly:: Thanks
    login as: dbell
    dbell@152.61.213.8's password:
    Legacy database exported to /flash/config/legacy_db.udb. Please save to
    external server and delete it.
    WARNING: This controller has RAP whitelist data
    stored in pre-6.3 format, which is consuming excess flash space. You will
    need this data if you ever need to downgrade the software to pre-6.3
    release. If you have backed up your flash already, you may delete the
    pre-6.3 data by running the command 'local-userdb-ap del all'
    (Aruba_Dev) >?
    enable Turn on Privileged commands
    exit Exit this session. Any unsaved changes are lost.
    help Help on CLI command line processing and a
    Description of the interactive help system
    logout Exit this session. Any unsaved changes are lost.
    ping Send ICMP echo packets to the specified ip address.
    tracepath Trace path to the specified IPv6 address.
    traceroute Trace route to the specified ip address.
    (Aruba_Dev) >sh loginsessions
    login as: dbell-pr
    dbell-pr@152.61.213.8's password:
    Last login: Tue Jul 7 07:30:15 2015 from 152.61.42.6
    (Aruba_Dev) #show loginsessions
    Session Table
    ID User Name User Role Connection From Idle Time Session Time
    1 dbell root 152.61.42.6 00:00:45 00:08:01
    2 dbell-pr root 152.61.42.6 00:00:00 00:00:05
    3 dbell root 152.61.42.6 00:02:09 00:03:22
    (Aruba_Dev) #
    *Dennis Bell*
    *(605)594-6809*
  • 18.  RE: Aruba WLAN controller RADIUS VSA for non-administrative (read-only) access
    Posted Jul 07, 2015 09:45 AM
    In the NPS server eventviewer, see which attribute is being sent for each authentication.
  • 19.  RE: Aruba WLAN controller RADIUS VSA for non-administrative (read-only) access
    Posted Jul 07, 2015 10:39 AM
    Waiting for logs -- how would i capture the Aruba end in the Aruba logs.
    Here is my current logging
    LOGGING LEVELS
    Facility Level
    arm warnings
    network warnings
    security warnings
    system warnings
    user warnings
    wireless warnings
    *Dennis Bell*
    *(605)594-6809*
  • 20.  RE: Aruba WLAN controller RADIUS VSA for non-administrative (read-only) access
    Posted Jul 07, 2015 11:38 AM
    Network Policy Server granted access to a user.
    User:
    Security ID:GS\dbell
    Account Name:dbell
    Account Domain:GS
    Fully Qualified Account Name:/Dennis C Bell
    Client Machine:
    Security ID:NULL SID
    Account Name:-
    Fully Qualified Account Name:-
    OS-Version:-
    Called Station Identifier:000B866DC3C4
    Calling Station Identifier:My workstation
    NAS:
    NAS IPv4 Address:152.61.213.9
    NAS IPv6 Address:-
    NAS Identifier:-
    NAS Port-Type:Virtual
    NAS Port:0
    RADIUS Client:
    Client Friendly Name:A-CTRL-Aruba-DEV
    Client IP Address 192.168.0.1
    Authentication Details:
    Connection Request Policy Name:Extreme Switch RO or RW
    Network Policy Name:Aruba Wireless RO Access
    Authentication Provider:Windows
    Authentication Server:MY RADIUS server.gs.doi.net
    Authentication Type:MS-CHAPv2
    EAP Type:-
    Account Session Identifier:-
    Logging Results:Accounting information was written to the local log file.
    Quarantine Information:
    Result:Full Access
  • 21.  RE: Aruba WLAN controller RADIUS VSA for non-administrative (read-only) access
    Posted Jul 07, 2015 11:44 AM
    It does not say specifically what attribute it sent back.
    Turn on radius debugging:
    config t
    logging level debugging security process authmgr
    logging level debugging security subcat aaa
    Authenticate, then type "show log security 50" to see what attributes are sent back.
  • 22.  RE: Aruba WLAN controller RADIUS VSA for non-administrative (read-only) access
    Posted Jul 07, 2015 11:52 AM
    Jul 7 09:49:24 :124004: |authmgr| Select server for
    method=Management, user=dbell, essid=<>, server-group=RADIUS-Admin-auth,
    last_srv <>
    Jul 7 09:49:24 :124004: |authmgr| server=IGSKMNCNVS091, ena=1,
    ins=1 (1)
    Jul 7 09:49:24 :124038: |authmgr| Selected server IGSKMNCNVS091
    for method=Management; user=dbell, essid=<>, domain=<>,
    Jul 7 09:49:24 :121031: |authmgr| |aaa| [rc_api.c:972] Radius
    authenticate user dbell MS-CHAPv2 using server IGSKMNCNVS091
    Jul 7 09:49:24 :121031: |authmgr| |aaa| [rc_api.c:1283] :L2 User
    lookup failed, skipping Aruba-Port-ID
    Jul 7 09:49:24 :121031: |authmgr| |aaa| [rc_request.c:52] Add
    Request: id=32, srv=152.61.192.225, fd=82
    Jul 7 09:49:24 :121031: |authmgr| |aaa| [rc_server.c:1576] Sending
    radius request to IGSKMNCNVS091:152.61.192.225:1812 id:32,len:222
    Jul 7 09:49:24 :121031: |authmgr| |aaa| [rc_server.c:1586]
    NAS-IP-Address: 152.61.213.9
    NAS-Port-Id: 0
    NAS-Port-Type: 5
    User-Name: dbell
    Service-Type: Administrative-User
    Calling-Station-Id: 152.61.42.6
    Called-Station-Id: 000B866DC3C4
    Framed-IP-Address: 152.61.42.6
    Vendor-Specific: \204\220YqW\273\354D\240\365x\241\017={\025
    Vendor-Specific:
    Aruba-Essid-Name:
    Aruba-Location-Id: N/A
    Aruba-AP-Group: N/A
    Aruba-Device-Type:
    Message-Auth: %\2447\276\213~cl\037&\276z
    Jul 7 09:49:25 :121031: |authmgr| |aaa| [rc_request.c:76] Find
    Jul 7 09:49:25 :121031: |authmgr| |aaa| [rc_request.c:82] Current
    entry: srv=152.61.192.225, fd=82
    Jul 7 09:49:25 :121041: |authmgr| User dbell MAC=00:00:00:00:00:00
    not found.
    Jul 7 09:49:25 :121031: |authmgr| |aaa| [rc_request.c:37] Del
    Jul 7 09:49:25 :121031: |authmgr| |aaa| [rc_api.c:1139]
    Authentication Successful
    Jul 7 09:49:25 :121031: |authmgr| |aaa| [rc_api.c:1141] RADIUS
    RESPONSE ATTRIBUTES:
    Jul 7 09:49:25 :121031: |authmgr| |aaa| [rc_api.c:1156] {Aruba}
    Aruba-User-Role:
    Framed-Protocol: PPP
    Service-Type: Framed-User
    Jul 7 09:49:25 :121031: |authmgr| |aaa| [rc_api.c:1156] Class:
    \313\301\012\266
    {Microsoft} MS-MPPE-Recv-Key:
    \200i)#\373gu.\3355\363U\306\373uphW%\257hx\335:@
    \345\205I\257\020\245\035\026\264
    {Microsoft} MS-MPPE-Send-Key:
    \200jy\274\214\025\260\002\200>\014\343\270kzGH}\360\215\216\272b\250\363\2753p\011&49*\261
    {Microsoft} MS-CHAP2-Success: EEDD138311144709217664E5020A48DE520BD
    {Microsoft} MS-CHAP-Domain:
    PW_RADIUS_ID:
    Rad-Length: 236
    PW_RADIUS_CODE: \002
    PW_RAD_AUTHENTICATOR: \250\364V\037\353\231\3626?\223\351M/\210\321\247
    Jul 7 09:49:25 :124066: |authmgr| Administrative User
    result=Authentication Successful(0), method=Management, username=dbell
    IP=152.61.42.6 auth server=IGSKMNCNVS091
    Jul 7 09:49:25 :124003: |authmgr| Authentication
    server=IGSKMNCNVS091, user=152.61.42.6
    Jul 7 09:49:25 :124004: |authmgr| Auth server 'IGSKMNCNVS091'
    response=0
    Jul 7 09:49:25 :124004: |authmgr| server_cbh (462)(DEC) : os_auths
    0, s IGSKMNCNVS091 type 2 inservice 1 markedD 0 sg_name RADIUS-Admin-auth
    Jul 7 09:49:25 :124446: |authmgr| mschap2: found chap2 success
    attribute
    Jul 7 09:49:25 :124025: |authmgr| Administrative user 'dbell'
    authenticated successfully (role=root, privileged=0)
    Jul 7 09:49:33 :124004: |authmgr| Auth GSM: Num dev_id_cache
    entries aged = 0
    Jul 7 09:49:33 :121031: |authmgr| |aaa| [rc_sequence.c:115]
    seq_num_timeout_handler: Freed 0 entries
    (Aruba_Dev) #
    *Dennis Bell*
    *(605)594-6809*
  • 23.  RE: Aruba WLAN controller RADIUS VSA for non-administrative (read-only) access
    Posted Jul 07, 2015 12:46 PM
    You are sending back an Aruba-User-Role attribute instead of an Aruba Administrative Role attribute.
    Create a separate remote access policy and put it on the top of your policies.  The condition Must have type of Virtual or VPN so it can be differentiated from Wireless Users.  Virtual or VPN is used for administrative access:
    You then Add your Vendor Specific Attribute with Aruba's VSA Number or Vendor Code:
    You click on Configure Attribute to Configure What you are sending Back:  The Vendor Assigned Attribute of 4 is the Aruba's VSA for Aruba-Admin-Role:
    (Aruba7005-US) #show aaa radius-attributes | include Aruba-Admin-Role
    Aruba-Admin-Role                  4      String       Aruba      14823
    So, I configure it with the number 4 and put in the "read-only" string that I want to send back:
    When I login, this is what is seen on the controller to validate who I am, my role and how I got that role:
    (Aruba7640-US) #    whoami
    user employee - role read-only
    (Aruba7640-US) #show loginsessions
    Session Table
    1   employee   read-only  192.168.1.84     00:00:00   00:01:36
    2   admin      root       192.168.1.84     00:01:44   00:01:49
    3   admin      root       192.168.1.84     00:03:08   00:03:30
    Jul 7 11:36:15 :124038:  <INFO> |authmgr|  Selected server NPS for method=Management; user=employee,  essid=<>, domain=<>, server-group=NPS
    Jul 7 11:36:15 :124004:  <DBUG> |authmgr|  aal_authenticate (851)(INC) : os_auths 1, s NPS type 2 inservice 1 markedD 0 sg_name NPS
    Jul 7 11:36:15 :121031:  <DBUG> |authmgr| |aaa| [rc_api.c:471] Radius authenticate user (employee) PAP using server NPS
    Jul 7 11:36:15 :121031:  <DBUG> |authmgr| |aaa| [rc_api.c:1319] :L2 User lookup failed, skipping Aruba-Port-ID
    Jul 7 11:36:15 :121031:  <DBUG> |authmgr| |aaa| [rc_request.c:53] Add Request: id=9, srv=192.168.1.25, fd=82
    Jul 7 11:36:15 :121031:  <DBUG> |authmgr| |aaa| [rc_server.c:1740] Sending radius request to NPS:192.168.1.25:1812 id:9,len:162
    Jul 7 11:36:15 :121031:  <DBUG> |authmgr| |aaa| [rc_server.c:1752]  NAS-IP-Address: 192.168.1.3
    Jul 7 11:36:15 :121031:  <DBUG> |authmgr| |aaa| [rc_server.c:1752]  NAS-Port-Id: 0
    Jul 7 11:36:15 :121031:  <DBUG> |authmgr| |aaa| [rc_server.c:1752]  NAS-Port-Type: 5
    Jul 7 11:36:15 :121031:  <DBUG> |authmgr| |aaa| [rc_server.c:1752]  User-Name: employee
    Jul 7 11:36:15 :121031:  <DBUG> |authmgr| |aaa| [rc_server.c:1756]  Password: *****
    Jul 7 11:36:15 :121031:  <DBUG> |authmgr| |aaa| [rc_server.c:1752]  Service-Type: Administrative-User
    Jul 7 11:36:15 :121031:  <DBUG> |authmgr| |aaa| [rc_server.c:1752]  Calling-Station-Id: 192.168.1.84
    Jul 7 11:36:15 :121031:  <DBUG> |authmgr| |aaa| [rc_server.c:1752]  Called-Station-Id: 000B86B8B5F8
    Jul 7 11:36:15 :121031:  <DBUG> |authmgr| |aaa| [rc_server.c:1752]  Framed-IP-Address: 192.168.1.84
    Jul 7 11:36:15 :121031:  <DBUG> |authmgr| |aaa| [rc_server.c:1752]  Aruba-Essid-Name:
    Jul 7 11:36:15 :121031:  <DBUG> |authmgr| |aaa| [rc_server.c:1752]  Aruba-Location-Id: N/A
    Jul 7 11:36:15 :121031:  <DBUG> |authmgr| |aaa| [rc_server.c:1752]  Aruba-AP-Group: N/A
    Jul 7 11:36:15 :121031:  <DBUG> |authmgr| |aaa| [rc_server.c:1752]  Aruba-Device-Type:
    Jul 7 11:36:15 :121031:  <DBUG> |authmgr| |aaa| [rc_server.c:1752]  Message-Auth: \327\324\2531\315R\275\265\367u\024uImM\272
    Jul 7 11:36:15 :121031:  <DBUG> |authmgr| |aaa| [rc_request.c:77] Find Request: id=9, srv=192.168.1.25, fd=82
    Jul 7 11:36:15 :121031:  <DBUG> |authmgr| |aaa| [rc_request.c:83]  Current entry: srv=192.168.1.25, fd=82
    Jul 7 11:36:15 :121041:  <DBUG> |authmgr|  User employee MAC=00:00:00:00:00:00 not found.
    Jul 7 11:36:15 :121031:  <DBUG> |authmgr| |aaa| [rc_request.c:38] Del Request: id=9, srv=192.168.1.25, fd=82
    Jul 7 11:36:15 :121031:  <DBUG> |authmgr| |aaa| [rc_api.c:1175] Authentication Successful
    Jul 7 11:36:15 :121031:  <DBUG> |authmgr| |aaa| [rc_api.c:1177] RADIUS RESPONSE ATTRIBUTES:
    Jul 7 11:36:15 :121031:  <DBUG> |authmgr| |aaa| [rc_api.c:1192]  {Aruba} Aruba-Admin-Role: read-only
    Jul 7 11:36:15 :121031:  <DBUG> |authmgr| |aaa| [rc_api.c:1192]  Framed-Protocol: PPP
    Jul 7 11:36:15 :121031:  <DBUG> |authmgr| |aaa| [rc_api.c:1192]  Service-Type: Framed-User
    Jul 7 11:36:15 :121031:  <DBUG> |authmgr| |aaa| [rc_api.c:1192]  Class: \246\217\010\315
    Jul 7 11:36:15 :121031:  <DBUG> |authmgr| |aaa| [rc_api.c:1192]  PW_RADIUS_ID: \011
    Jul 7 11:36:15 :121031:  <DBUG> |authmgr| |aaa| [rc_api.c:1192]  Rad-Length: 95
    Jul 7 11:36:15 :121031:  <DBUG> |authmgr| |aaa| [rc_api.c:1192]  PW_RADIUS_CODE: \002
    Jul 7 11:36:15 :121031:  <DBUG> |authmgr| |aaa| [rc_api.c:1192]  PW_RAD_AUTHENTICATOR: \032GL\3508X\240\337\214OQ\022\247\335\311@
    Jul 7 11:36:15 :124066:  <INFO> |authmgr|  Administrative User result=Authentication Successful(0), method=Management, username=employee IP=192.168.1.84 auth server=NPS
    Jul 7 11:36:15 :124003:  <INFO> |authmgr|  Authentication result=Authentication Successful(0), method=Management, server=NPS, user=192.168.1.84
    Jul 7 11:36:15 :124607:  <DBUG> |authmgr|  server_cbh(): response=0 from Auth server 'NPS for client:9 proto:1 eap-type:0'.
    Jul 7 11:36:15 :124004:  <DBUG> |authmgr|  server_cbh (392)(DEC) : os_auths 0, s NPS type 2 inservice 1 markedD 0 sg_name NPS
    Jul 7 11:36:15 :124612:  <DBUG> |authmgr|  AuthSurv_onAuthSucc(authsurv:0): Entered, proto:1 eap-type:0x0 for username:'employee' auth-server:'NPS'.
    Jul 7 11:36:15 :124025:  <NOTI> |authmgr|  Administrative user 'employee' authenticated successfully  (role=read-only, privileged=0)
    Jul 7 11:36:17 :121031:  <DBUG> |authmgr| |aaa| [rc_sequence.c:115] seq_num_timeout_handler: Freed 0 entries
  • 24.  RE: Aruba WLAN controller RADIUS VSA for non-administrative (read-only) access
    Posted Jul 07, 2015 08:21 AM
    Nope.  Local management accounts will still work, if they were working before.  Local accounts already have attributes assigned so they always work.
  • 25.  RE: Aruba WLAN controller RADIUS VSA for non-administrative (read-only) access
    Posted Jul 07, 2015 08:23 AM
    You are wrong. I am locked out completely!!!!!
  • 26.  RE: Aruba WLAN controller RADIUS VSA for non-administrative (read-only) access
    Posted Jul 07, 2015 08:26 AM
    Dbell6809,
    If you do not allow local accounts to authenticate while Radius is working, and you are NOT sending back an adminstrative role in the VSA, you would not be able to access your controller, no.
  • 27.  RE: Aruba WLAN controller RADIUS VSA for non-administrative (read-only) access
    Posted Jul 07, 2015 08:44 AM
    Dbell,
    If you are completely locked out, please look at the document in the post here: http://community.arubanetworks.com/t5/Monitoring-Management-Location/Management-Authentication-using-Windows-2008-as-a-Radius-Server/ta-p/174672
    The post is for Airwave.  The controller just requires the attribute "root" instead of "Admin" on page 18 for it to work.
  • 28.  RE: Aruba WLAN controller RADIUS VSA for non-administrative (read-only) access
    Posted Jul 07, 2015 09:03 AM
    Thanks! I did get in by disconnecting the network cable briefly and logging
    in from the console port. My issues were due to the fact that I do not
    have RADIUS administrative rights anymore.
    <Personal Info Removed>
