Aruba wifi controller requesting priv-level=15 on a read-only account.
Hi there me again. I have now moved to working on read-Only access on an Aruba Wi-Fi controller.
We have Aruba CPPM set-up to return the read-only role using the 'Aruba:common' setting for Aruba-Admin-Role role=read-only
The authentication works then I get the following error message for the privilege level:
INFO AAA.AuthenLoginSession - completeAuthentication: Requested priv_level=15 greater than Max Allowed priv_level=0
The CPPM is set with the priv_level service set to 0 - I can get it working if I set that to 15 but then it isn't a read-only account and changes can be performed on the controller. I am guessing I am probably missing a setting somewhere as to why the controller is requesting priv_level=15
The default-role on the controller is read-only:
aaa authentication mgmt
   server-group "AAAservers"
   default-role read-only
   enable
This works fine for our Read-Write settings but I can't get Read-Only working on the GUI using the root Aruba-Admin-Role. Any pointers?
Kind regards,
Z
Re: Aruba wifi controller requesting priv-level=15 on a read-only account.
You will need to have to Roles defined.
Here is an exaple of my controller tacacs
Thank You,
Troy
Troy,
Thanks for your reply. We do have it set-up like your eample with the read-only role on CPPM. The thing is if we use priv_level=15 then the access is not read-only as per the documentation:
read-only
Permits access to CLI show commands or WebUI monitoring pages only.
When I log in with the read-only accuont and priv_level=15 set it allows me to log in no problem but then I have access to everything. I can view and change the configuration window in the WebUI so defeats the object. I am setting this up for our security team so they wouldn't be too happy about having configuration options. On the CLI I can run configure terminal too which I don't want to be able to do. Have you checked your read-only account only gives you show commands and WebUI monitoring pages?
If I try using a lower priv_level on the CPPM it fails to authenticate due to the level requested by the controller being 15 but for read-only surely it should be lower?
I have logged a call with our support company but they haven't come up with a solution yet.
Kind regards,
Z
I am having the same issue and Aruba TAC has not come up with a solution yet. Any new insight?
I am using the read only settings but the users seem to get priviledge exec access... Any updates on this?
