MVP
Auto Send SMTP Checkbox on Guest Self-Registration
Hey,
CPPM Ver: 6.4.2.30915
I am have been playing around with our guest portal trying to make a little more user friendly. I was experimenting with the option "Auto-send guest receipts by email with a special field set".
I was testing the functionality with a checkbox with the default field "auto_send_smtp".
I had it working. But since upgrading to the latest version of CPPM it appears to have stopped working with a checkbox.
I have also tested with a radio button and am in the process of testing with a textbox.
I tried changing the Guest Self-Registration settings to "Always auto-send guest receipts by email" and this worked. I was able to receive the receipt on the personal email address I was using to do my tests.
Just curious if some functionality changed in the latest version of CPPM? Or is there maybe a recommended way of using this functionality?
Thank you,
Cheers
Re: Auto Send SMTP Checkbox on Guest Self-Registration
bourne,
Have you tried it like below?  (The rank may differ on your setup).
6.3.1 changed how that field is evaluated.  Please try the one below.
MVP
Hey,
I just tried changing to the settings you have. Although I used the field name "auto_send_smtp". I see the option though for "auto_send_sms", should I be using that even though I want to send an email?
At any rate, testing with the settings shown in your screenshot (but with auto_send_smtp), I am still not receiving the email.
Guest Self-Registration portal settings
Form hidden field settings
Form setting with Checkbox
I must be configuring something else incorrectly.
Thank you,
Cheers
Please try it like below:
MVP
It looks like the field is defaulted to the values you have in your screenshot.
I didn't modify the values shown in my screenshot.
MVP
On a side note I tried the option "Display a link enabling a guest receipt via email".
Once I authorized the account  (sponsored) I received the link and by clicking this link I received the email to my personal email account.
If you have the field on the right form it should work. Please have TAC take a look.
MVP
Will do.
Thanks for your support!
Cheers
MVP
Opened a case today.
Will report findings.
Cheers
