Frequent Contributor II
Auto-send mail doesn't work after upgrade to 6.7.2 - Unprocessable Entity
One of our customers has a problem after upgrading to release 6.7.2; we did this a few months ago, but we only noticed it now.
When I send a test-mail, I can see on the page itself I receive an OK, test mail send successfull, but I never receive the mail. When I check the application logs, I receive an API error.
But as far as I know we use the default configuration of auto-sending an e-mail. It used to work, but now it fails.
We receive 2 errors; The first:
Client:    127.0.0.1:36996
App User:  localhost
Script:    /guest/apigility.php
Function:  ClearPass\Api\RestfulApi::create
Arguments: array (
  'data' => object(stdClass) (
Details:   array (
  'validation_messages' => array (
    0 => 'FAILURE',
    1 => false,
  'http_status' => 422,
The second:
API call ‘POST /api/email/send’ returned an error
This is the error I receive:
  'output' => array (
    'api_problem' => array (
        0 => 'FAILURE',
        1 => false,
      'type' => 'http://www.w3.org/Protocols/rfc2616/rfc2616-sec10.html',
      'title' => 'Unprocessable Entity',
      'status' => 422,
      'detail' => 'FAILURE
  'time_elapsed' => 0.20592594146729,
Anyone had this issue before?
Kind regards,
Thomas
Thomas
ACMX#370 ACCX#1000
Re: Auto-send mail doesn't work after upgrade to 6.7.2 - Unprocessable Entity
Please upgrade to 6.7.3
Tim Cappalli | Aruba Security
Ok, will try to do this in the next couple of weeks, during a maintenance window
Thomas
ACMX#370 ACCX#1000
OK, we had a maintenance window and we upgraded, but same issue persists ... any idea... or TAC?
Thomas
ACMX#370 ACCX#1000
