Contributor I
CPPM Cluster and Certificates
In a cppm cluster configuration , we have two nodes one publisher and one subscriber and vip is configured.
Do i need to install two seperate server certificates for each of the nodes, I have seen the certificate which was installed in the first node before making as cluster has replicated to the subscriber. But does this work in the event of a subscriber failure as the fqdn of the subscriber is different .cppm1.abc.com and cppm2.abc.com
What are the considerations in cluster enviornment with VIP configured regarding  certificates, COA , onboard etc..
I have seen a document for onguard in the culster enviornment , do you have any other docs/pointers.
Re: CPPM Cluster and Certificates
Please see the article here:  http://community.arubanetworks.com/t5/AAA-NAC-Guest-Access-BYOD/Certificate-Issues-Questions/td-p/94444
Typically you would want to use a SAN cert for clusters.
CN=VIP
SAN=VIP,CPPM1,CPPM2
Your local SE should be able to give you a document on certs.
Thank You,
Troy
Contributor II
Hi all,
we are planning to do clustering in L3 enviroment.
Can i use same server certificate for both  clearpasses so that if subscriber fails publisher can authenticate onboarded devices instead of going for SAN.
If publisher goes down, subscriber can be promoted to active publisher and it can authenticate traffic which comes to publisher.
I have a doubt when i went through tech note. they are suggesting not to go with Virtual IP in L3 enviroment.How to do clustering over L3???
And if we onboard at subscriber location, devices gets regiesters in publisher and then replicated subscriber or gets registered in subscriber and replicates to publisher. I am bit confused .
Yes you can use the same cert but it should be a SAN. I do this in most deployments.
Tim Cappalli | Aruba Security
Contributor II
I have already 200 devices onboarded in main location and we have deployed new setup in remote location.
I have configured only CN. to configure again i have to create signing request with SAN.
I have to re onboard all the devices ri8 to work fail over???
No. The RADIUS server certificate does not impact your Onboarding.
Yes, everything is replicated to the subscriber but only the publisher has write access to the database.
Contributor II
but u said it should be SAN. generally cppm looks for CN ri8 if SAN is not given.
No...but on publisher which has 200 devices. Cant I go with with jus CN and importing publisher certificate in subscriber.
My CPPM host name is different and CN is different and TAC has said that it wont work with CN having different name which is not hostname has it wont resolve DNS.
How is CN is related to DNS?? im fully confused
What is the host name and what is the CN?
srikanthsoogoor,
Please feel free to download the ClearPass Certificates Technote written by our own Danny Jump here :  http://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/Command/Core_Download/Default.aspx?EntryId=13734
