last person joined: 5 hours ago
CPPM Radius with LDAP question
  • 1.  CPPM Radius with LDAP question
    Posted Oct 02, 2017 07:06 AM
    I have an Aruba Controller and a CPPM. I need to know if it is possible to configure this scenario:
    - Configure a Radius server (CPPM) inside Aruba controller.
    - Create a captive portal inside CPPM where users will must be enter user/pass.
    - Once CPPM receives the user/pass introduced by users trhough CPPM's Captive Portal, It has to verfy it against an external LDAP server.
    I need set the configuration flow of this scenario.  Could you help me?
    Regards
  • 2.  RE: CPPM Radius with LDAP question
    Posted Oct 02, 2017 07:36 AM
    What specifically do you need help with? This is a pretty standard setup.
  • 3.  RE: CPPM Radius with LDAP question
    Posted Oct 02, 2017 07:47 AM
    Thank you for your reply.
    I need to configure a SSID in the Aruba controller where users will be redirected to a captive portal inside CPPM to enter user and pass. To make it I understand that I have to:
    - Creat a Captive Portal auth profile
    - A server group
    - Configure inside server group a Radius Server (CPPM)
    - An user role
    - A captive portal aaa profile
    And at the end, associate all this profiles and roles to the SSID created on the Aruba Controller.
    (Correct me If I'm wrong)
    I need to know the configuration flow to configure the CPPM, I need that:
    - Captive portal configured inside it.
    - Controller association
    - Once the controller init the authentication with its radius server (CPPM) and users have entered their credentials, I need that CPPM check this user/pass against an external LDAP server.
