Captive portal
  • 1.  Captive portal
    Posted Aug 26, 2017 06:40 AM
    Hy, I am trying to deploy the aruba central cloud guest to social login with facebook in my company, however a certificate error message is displayed.My clients are having difficulty accessing the network because an invalid certificate message is displayed. How to disable HTTPS on captive portal?
    I am using an IAP 225 with central aruba and guest token
  • 2.  RE: Captive portal
    MVP EXPERT
    Posted Aug 27, 2017 04:44 AM
    What is the invalid certificate error you are seeing? My concern is that if you disable https then essentially any Facebook credentials to the external Captive Portal are surely unencrypted?
  • 3.  RE: Captive portal
    Posted Aug 28, 2017 12:55 AM
    Hi Dan,
    Can you describe, where you see the invalid error message?
    Normally, you will always see this message, when you redirect to a captive portal. The reason for this is that the browser is trying to connect to something like "https://www.google.com" and is expecting a certificate from www.google.com. But due to the redirect, it is getting a certificate for e.g. securenetworks.arubanetworks.com. This mismatch creates the invalid certificate message. There is no way to avoid this.
    You can only get around this, by not using a HTTPS enabled page for the first place like "http://www.google.com". but this heavily depends on the default settings of your client machines.
    Disabling HTTPS on the captive portal page itself will also solve it, but I would never recommend doing so. This will make the credentials visible to anyone within the range of your WLAN.
