ClearPass 6.6.1: AirWatch: Enable to fetch Endpoint Security Info
  • 1.  ClearPass 6.6.1: AirWatch: Enable to fetch Endpoint Security Info
    MVP GURU
    Posted Jul 25, 2016 10:33 AM
    It is possible to have more information about this new option with ClearPass 6.6.1 ? when setting a AirWatch Endpoint Context Server
    Because the documentation is (not) yet update : http://www.arubanetworks.com/techdocs/ClearPass/6.6/PolicyManager/index.htm#CPPM_UserGuide/Admin/EndpointContextServersAdd_airwatch.htm?Highlight=airwatch
  • 2.  RE: ClearPass 6.6.1: AirWatch: Enable to fetch Endpoint Security Info
    Posted Jul 25, 2016 10:38 AM
    From the 6.6.1 release notes:
  • 3.  RE: ClearPass 6.6.1: AirWatch: Enable to fetch Endpoint Security Info
    MVP GURU
    Posted Jul 25, 2016 10:43 AM
    Yes, i have read the release note...
    But what is the "Security Info" ?
  • 4.  RE: ClearPass 6.6.1: AirWatch: Enable to fetch Endpoint Security Info
    Posted Jul 25, 2016 10:50 AM
    If you check the box, it will pull in all of the extra attributes from AirWatch.
  • 5.  RE: ClearPass 6.6.1: AirWatch: Enable to fetch Endpoint Security Info
    MVP GURU
    Posted Jul 25, 2016 12:12 PM
    Ok, What this extra attributes ?
  • 6.  RE: ClearPass 6.6.1: AirWatch: Enable to fetch Endpoint Security Info
    Posted Jul 25, 2016 05:24 PM
    Let me answer as this is an enhancement that as driven by myself.
    We poll for the summary and page in the data we get, parsing this and writing it into our Endpoint DB, we then make secondary calls for every endpoint for more security/policy specific attributes. Their are SIX TAGS in the device XML we get,
    IsCompromised
    DataProtectionEnabled
    BlockLevelEncryption
    FileLevelEncryption
    IsPasscodePresent
    IsPasscodeCompliant
    Now one of these XML TAG attributes <IsCompromised> is also available in the summary poll, its called <CompromisedStatus>.
    So by not polling for the security data we save a HUGE amount of extra polling but we do lose the ability to have certain endpoint attributes data available to be used by CPPM in its enforcement process.
    But, I've had a number of very large customers 75K+ devices who don't care about the security data but do care about the large overhead of the secondary polling, plus it absolutely kills Airwatch servers.
    HTH
