ClearPass / Cisco Wired - Named VLAN Enforcement
  • 1.  ClearPass / Cisco Wired - Named VLAN Enforcement
    MVP
    Posted Oct 24, 2017 03:14 PM
    Hey all,
    I've been searching around and can't seem to find the answer. If I'm doing wired 802.1X with cisco 2960X that supports named VLANs, what do I need to configure in CPPM enforcement profile to send named VLAN back?
    My thoughts: Enforcement type - VLAN Enforcement.  Private-Tunnel-ID set as VLAN name instead of VLAN number, but don't know if that's going to work.
    Can anyone show the proper way of doing this?
    Thanks.
  • 2.  RE: ClearPass / Cisco Wired - Named VLAN Enforcement
  • 3.  RE: ClearPass / Cisco Wired - Named VLAN Enforcement
    MVP
    Posted Oct 24, 2017 03:20 PM
    Page 117, that's exactly what I'm looking for. That document will actually help with some other stuff I'm doing too, thanks for the help!
  • 4.  RE: ClearPass / Cisco Wired - Named VLAN Enforcement
    Posted Jun 01, 2018 02:47 PM
    hello Tim
    i went through your document, and it helps a lot,
    for Cisco IOS section, i'm wondring how you configured the enforcement profile of EDGE_GUEST(vlan name)
    i tried the bellow but doesn't work
    profile template : Vlan enforcement
    and instead of :
     Type: Radius:IETF         name:Tunnel-Private-Group-Id    value: 200
    i changed it with:
    Type: Radius:IETF        name: Egress-VLAN-Name           value: DATAVLAN
    But it doesn't work unfortunetly
    note: in my cisco switch vlan id : 200 is named DATAVLAN
    waiting for your feedback Tim
  • 5.  RE: ClearPass / Cisco Wired - Named VLAN Enforcement
    Posted Jun 01, 2018 03:09 PM
    The VLAN name goes as Tunnel-Private-Group-Id as documented.
  • 6.  RE: ClearPass / Cisco Wired - Named VLAN Enforcement
    Posted Jun 02, 2018 08:02 PM
    hello Tim,
    witch mean
    Type: Radius:IETF name:Tunnel-Private-Group-Id value: DATAVLAN
    should work for my case right ?
  • 7.  RE: ClearPass / Cisco Wired - Named VLAN Enforcement
    Posted Jun 03, 2018 05:30 AM
    Yes.
  • 8.  RE: ClearPass / Cisco Wired - Named VLAN Enforcement
    Posted Dec 16, 2019 07:34 PM
    Great document and post,this:Type: Radius:IETF name:Tunnel-Private-Group-Id value: DATAVLAN
    will look for the exact name vlan or even if contain the keyworks DATAVLAN should works?  examplae:
    vlan id:    coporate-datavlan
    greetings
  • 9.  RE: ClearPass / Cisco Wired - Named VLAN Enforcement
    MVP
    Posted Dec 16, 2019 07:50 PM
    Has to be exact match to VLAN name already on switch.
  • 10.  RE: ClearPass / Cisco Wired - Named VLAN Enforcement
    Posted Dec 16, 2019 07:51 PM
    thank you!
