ClearPass Guest: difference between "Save Changes" and "Save and Reload" button
  • 1.  ClearPass Guest: difference between "Save Changes" and "Save and Reload" button
    Posted May 03, 2013 05:36 AM
    very simple question but can't seem to find it in the documentation.
    is in clearpass guest (version 6 if it matters) the difference between "Save Changes" and "Save and Reload" button only if you stay on the page or return to the page before it?
  • 2.  RE: ClearPass Guest: difference between "Save Changes" and "Save and Reload" button
    Posted May 03, 2013 05:46 AM
    Depending on the web browser you use and if you have pop up blocker turned on. Save and reload will either open a new window or tab with the page you just created or updated.
  • 3.  RE: ClearPass Guest: difference between "Save Changes" and "Save and Reload" button
    Posted May 03, 2013 10:32 AM
    hmm odd, with me it just shows the same page in the same tab. anyway the effect is the same right, the configuration is saved?
  • 4.  RE: ClearPass Guest: difference between "Save Changes" and "Save and Reload" button
    Posted May 03, 2013 11:58 AM
    Correct. The save and reload is just handy way of you previewing your page when you are done editing it. I have see your issue only when popup blocker is enabled.
    What browser are you using i would like to see if I can replicate your issue?
    Thank you,
    Troy
  • 5.  RE: ClearPass Guest: difference between "Save Changes" and "Save and Reload" button
    Posted Feb 24, 2014 04:24 AM
    took a while, but tested it today and it works like you explain, probably browser issue before.
