Frequent Contributor I
ClearPass Integration with SendGrid
I had follow this link to make a Context Server action
https://community.arubanetworks.com/t5/ClearPass-Recipes/SendGrid-Email-Notification/ta-p/204343
I would like to add the MAC Address of the device.
Someone can help me to build the JSON Content?
  "personalizations": [{
  "to": [{
  "email": "email@domain.com"}]}],
  "from":{
  "email": "clearpass@dmain.lab"},
  "subject": "Device Unhealthy",
  "content": [{
  "type": "text/plain",
  "value": "The device (I DON'T KNOW) compromised."}]}'
Many thanks.
Ricardo Luis Cañavate García - ACMP / ACCA / ACCP / ACDX#972
Re: ClearPass Integration with SendGrid
%{Connection:Client-Mac-Address}
Tim Cappalli | Aruba Security
Thanks for reply, I had solved two minutes after wrote the question, but I couldn't delete the question. Regards.
