Contributor I
ClearPass MAB EAP-MD5 with MSSQL
Ciao,
Do you know if it's possible to autenticate mac-address using MSSQL when the switch uses EAP-MD5 as protocol?
Re: ClearPass MAB EAP-MD5 with MSSQL
Evaluate the MAC address during the authentication phase. For the authentication phase, do an Allow All MAC Auth.
Tim Cappalli | Aruba Security
Contributor I
Not the [EAP MD5] ???
If the switch can only do EAP-MD5, you'll need to do this workaround.
  1. Extract and Import the attached static host list.
  2. Create a new Static Host List authentication source and select the SHL previously imported
  3. Use this as the auth source along with [EAP MD5] as the method
  4. Add the SQL auth source as an additional authorization source
SRM
Occasional Contributor I
s
Contributor I
Thanks Tim
However now I've this error regarding authorization. I attach the logs and SQL  cfg
1) Your query for MAC address should be %{Connection:Client-Mac-Address} instead of username
2) Does the query work when you test in the attribute builder?
