ClearPass Tips and Tricks :Custom Attributes /Insight Repository /Web-Login(Server-Initiated)
This thread has been viewed 27 times
  • 1.  ClearPass Tips and Tricks :Custom Attributes /Insight Repository /Web-Login(Server-Initiated)
    Posted Feb 26, 2015 11:05 PM
    This is an illustration of a recent scenario during the implementation process for one of our customers.
    Customer Requirements:
    Solution
    - Use ClearPass Onguard Persistant Agent as NAC solution for the following devices:
    • Domain Windows Laptops
    • Non-Domain Windows Laptops
    • Mac OS X
    -  How to distribute the Onguard Persistent Agent based on the device type:
    • Domain Windows Laptops : Distribute the Onguard Persistent Agent using a Windows Group Policy (GPO)
    • Non-Domain Windows Laptops and Mac OS X : Redirect the user to a Captive Portal page to download the Onguard Agent
    - Allow users with Non-Domain Devices to Bypass the Captive Portal page to download the Onguard Agent and provide Internet Only Access
    Software Requirements:
    - ClearPass:
    • Policy Manager License
    • Guest Module License
    • Onguard Module License
    • Version 6.3.6.x and Up
    - Aruba Controller
    • Version 6.4.2.1 and up
    • Aruba Policy Enforcement Firewall License
    To accomplish this I will  use the following ClearPass features:
    • Endpoint Database (Custom Attributes)
    • Post Authentication Enforcement Profile
    • Insight Repository (Successful-Login-Count)
    • Web-Login (Server-Initiated)
    FLOWCHART:
    Note: This flowchart only includes the logic for the Agent Bypass configuration
    CLEARPASS CONFIGURATION
    1 - Endpoint Custom Attributes
    We can use custom attributes to tag devices and then use that tag to make a decision on the enforcement policy
    1.1 - Create attribute BYPASS-ATTR that will be use to tag the device if the user decides to bypass and not download the Onguard Agent
    2 - Post Authentication Enforcement Profile
    The post authentication enforcement profile allows us to make updates to certain/devices and in this case to the endpoint database , we will create two post auth enforcement profiles:
    2.1 - The BYPASS-ATTR-UPDATE will add the BYPASS-ATTR=Yes to the device during the WEBAUTH when the user bypass the installation of the Onguard Agent
     2.2 - The NO-BYPASS-ATTR-UPDATE will add the BYPASS-ATTR=No , the first time the device connects past 12AM which in this case the user will be redirected to download the Onguard Agent.
    3 -  Web Login Page
    This will be the page we will use to redirect the users to download the persistent Onguard Agent.
    3.1- Create a Web Login Page with the following :
    • Server-Initiated login method , the web authentication will be processed by the ClearPass server but in order for this to work the mac address of the device needs to be included in the browser
    • Anonymous Login (Creates a Guest Account with no limits)
    • The page will present which Onguard Agent to installed based device OS  (Mac or Windows)
    • Custom button "EXTERNAL"
    • Assign a Login Delay of 25 seconds to give time for the CoA/PostAuth Attributes that is added during the WEBAUTH service and 802.1X Reauth to occur
    Note: Once the Web Login is created the guest account will show up in the guest user repository , make sure that this account doesn't get deleted
    4- Web Auth Service
    The web auth service will be use to do the following:
    • Do a successfull authentication using the Anonymous Guest Account
    • Tag device with the BYPASS-ATTR-UPDATE-PROFILE / BYPASS-ATTR=Yes
    • Perform a CoA
    4.1 - First we need to define the Guest User Repository as the Authentication Source and use it as an Authorization Source
    4.2 - In the WEBAUTH Role Mapping we will label the Anonymous Guest Account with the tips BYPASS-ROLE (This portion is OPTIONAL) , I used this method because it makes easier when troubleshooting in access tracker and determine what logic should be applied based on the label
     4.3 - Use the tips BYPASS-ROLE as a condition to apply the Post Auth Enfocerment Profile and the CoA
    5- 802.1x Auth Service
    The 802.1x Auth Service will be use for the following purposes:
    • Authenticated 802.1x capable devices and provide access based on the posture and type of device.
    • Redirect a NON-Domain device (Windows/Mac OSX) to download the agent if these have an "UNKNOWN" posture and connected to wireless network for the first time since 12AM.
    • Provide Internet Only Access if the device bypassed the Onguard Agent page and has been connected more than once since 12AM.
    5.1 - The PERSISTENT-ONGUARD-PROFILE Radius enforcement profile will be use to send back to the controler the Aruba-User-Role = PERSISTENT-ONGUARD-CP-ROLE and this controller role will allow the user to be redirected to the Onguard Agent Download Page
    5.2 - The INTERNET-ACCESS-PROFILE Radius enforcement profile will be use to send back to the controler the Aruba-User-Role = INTERNET-ACCESS-ROLE and this controller role will be use for users that bypass the Onguard Agent download page
    5.3 - 802.1x Role Mapping will be use for the following purposes:
    • Label the device with a Successful-Login-Count ≤ 1 with the FIRST-LOGIN-PAST-12AM tips role
    • Label the device with a Successful-Login-Count ≥ 2 with the NON-FIRST-LOGIN-PAST-12AM tips role
    • Label the device tagged with the BYPASS-ATTR = Yes with the BYPASS-ROLE tips role
    5.4- The 802.1x Enforcement Policy uses the following logic :
    • Third Rule: A brand new NON-Domain Computer (Windows or Mac OSX) with an "UNKNOWN" posture will be redirected to the Onguard Agent Download Page.
    • First Rule: If the user decides to Bypass the Onguard Agent Download Page then the user will get the Internet Only access user-role.
    • Second Rule: When a user connect using a device tagged with the BYPASS-ATTR=Yes , comes back and authenticates for the first time after 12AM it will be redirected to the Onguard Agent Download Page.
    6- Validation
    6.1 - A brand new NON-Domain Computer (Windows or Mac OSX) performs an 802.1x authentication and it has an "UNKNOWN" posture it will be redirected to the Onguard Agent Download Page.
    6.2 - The user is presented with the Web-Login (Server-Initiated) / Onguard Agent Download Page.
     6.3 - Once the user clicks on the "EXTERNAL ACCESS" button it will initiate the WEBAUTH with the Anonymous Login using the Guest Account=72306207, there's also a "25 Seconds" Delay that is added to the Web Login so there's enough time for the whole process to complete.
    2015-02-26 13_31_52-https___192.168.1.100_guest_download_agent_page.php__browser=1.png
    6.3.1- Here's closer look at some of the details of WEBAUTH request from the Summary Tab
    6.4- When the BYPASS-ATTR=Yes tagged device performs the 802.1x reauth it will receive the Internet Access only user-role
