Frequent Contributor II
ClearPass build question...
What would the minimum requirements needed to have the ClearPass OnGuard & Guest modules for a 500 user license? I am trying to get quotes from vendors but I want to know exactly what I need ahead of time.
As always, any help/advice is greatly appreciated!!
Scott McNeil - Sr. Network & Security Engineer, Global Process Automation
Network+ | CWNA | CWTS | ACSP | ACMP | ACMA | BREC
