Frequent Contributor I
ClearPass joining AD timeout problem
Hi all,
Hope someone will be able to point me in right direction. We are trying to join customer's ClearPass server to an ADs. Joining it to the first one went perfectly OK (in scenario where both boxes have interfaces on the same subnet). When trying to join second AD (in scenario where there is a firewall between them, **but not saying that this is firewall issue, just explaining setup!**) we run into problems. ClearPass attempts to join new AD and fails showing this message:
"Adding host to AD domain...
INFO - Fetched REALM 'XXXXX.COM' from domain FQDN
'ltcs.XXXXX.com'
INFO - Fetched the NETBIOS name 'XXXXX'
INFO - Creating domain directories for 'XXXXX'
Enter CPPMService's password:
cli_rpc_pipe_open_noauth: rpc_pipe_bind for pipe \netlogon failed
with error NT_STATUS_IO_TIMEOUT
libnet_join_ok: failed to get schannel session key from server
ltcs.XXXXX.com for domain XXXXX. Error was NT_STATUS_IO_TIMEOUT
Failed to join domain: failed to verify domain membership after
joining: NT_STATUS_IO_TIMEOUT
INFO - Restoring smb configuration
INFO - Restoring krb5 configuration file
INFO - Deleting domain directories for 'XXXXX'
ERROR - CPPM004 failed to join the domain XXXXX.COM with
domain controller as ltcs.XXXXX.com
Join domain failed"
Packet capture on firewall shows traffic between nodes passing through (at least the one that is allowed by initial request: kerberos, Active Directory, ms-ds-smb, mspc, netbios-s).
Any thoughts are more than welcome. Thanks,
NesaM
NesaM --ACMP, ACCP--
Re: ClearPass joining AD timeout problem
Make sure that the time on the ClearPass box and the domain box are the same.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Thanks Colin,
Will check and confirm on Monday.
NesaM
Hi Colin,
TIme checked on both boxes, and it is in sync. Any thoughts where to look next? Thanks.
NesaM
Can you do an NSLOOKUP to that domain controller from ClearPass CLI
network nslookup
Get Outlook for iOS
Thank you
Victor Fabian
Lead Mobility Architect @WEI
network nslookup
Get Outlook for iOS
Thank you
Victor Fabian
Hi Victor,
Checked and it is coming back with the server IP. I asked customer to double-confirm if all the right ports are opened on fw, and will try to get hold of Event Log from AD controller.
NOTE: Case opened now with TAC, will keep you updated on what it was (though it must be something silly)
NesaM
Right, problem was after all related to Palo Alto. Original request was to allow these applications:
kerberos, Active Directory,ms-ds-smb, msrpc, netbios-ss, ldap
When observing traffic going through firewall no traffic was dropped. However, someone from that team noticed that MS logon protocol was not added by default (though this was apparently expected when you allow Active Directory on PA).
After adding MS logon all clicked nicely, and we now have happy customer. Thanks everyone who contributed with suggestions.
NesaM
