Frequent Contributor II
Clearpas Upgrade from 6.2 to 6.4 Issue?
In clearpass appllaince the internet is too bad so we downloaded the Bin.signed file from support and imported it and after finishing it gives 'Uploaded file is invalid, does not have meta file or unrecognised type or does not have valid signature' error and then disaappear from the software area how can I do the Upgrade?
Re: Clearpas Upgrade from 6.2 to 6.4 Issue?
You should contact TAC to get that resolved.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
is this is a bug or what?
You could have downloaded the wrong file or it is corrupt.  TAC would be able to direct you to the correct file and correct procedure.
Did you read the release notes on 6.4 ?
You should read on how to upgrade from 6.2 to 6.4
Thank you
Victor Fabian
Lead Mobility Architect @WEI
And if you continue to experience more issues you should consider opening a TAC like cjoseph suggested
Thank you
Victor Fabian
Thanks man really appriciated I will contact him and read the notes
