I'm looking for the correct syntax to read the contents of a Clearpass Device Group as well as add a member to an existing group via the API. I have successfully setup API calls to read and write endpoints, but I'm not sure the syntax for Device Groups. Thanks!
Get all device groups:
GET https://{{ClearPass-Base-URL}}/api/network-device-group
Get single device group:
GET https://{{ClearPass-Base-URL}}/api/network-device-group/{{device-group-id}}
Add device to device group:
PATCH https://{{ClearPass-Base-URL}}/api/network-device-group/{{device-group-id}}
{ "value": "100.81.0.11"}
NOTE. This will override the field, so if you are adding a value, you need suck in the old values, and append the new one.
Thank you - that pointed me in the right direction. The API URL is actually https://{clearpass-server}/tipsapi/config/read/NadGroup.
I was then able to build the XML and apply a filter criteria to get the specific groups I need. Should be relatively simple to build the XML to append to that list and write back to Clearpass. Thanks!
That's the legacy SOAP API. You should use the new RESTful API which is what I posted.
Ok, thanks - hadn't realized the API was updated.
Can you point me in the direction of documentation? I tried the URL you sent and it did not work - is there a minimum version for REST API support?
API explorer lives at /api-docs
High-level doc here: https://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/Command/Core_Download/Default.aspx?EntryId=22490
Thanks again, Tim - I'm getting 403 forbidden errors attemptin to just use the API explorer. Shouldn't the base HTTP authentication work for this purpose?
Yes - the redirect occurred and I logged in, but now I'm getting 403 errors using the API explorer. I encountered this issue in the past which had me resorting to the SOAP API.
Screenshot of the API explorer above. When I navigate to /api-docs, I'm redirected to Clearpass Guest to login, which is successful and then I'm redirected back to the /api-docs URL where I select NetworkDeviceGroup and try the GET method. Screenshot it the result.
