Frequent Contributor I
Clearpass Guest Redirection Issue
We are having issue after success guest registration certain Windows user cannot redirect to corporate website and to internet after click login button. If using Firefox, it will go to ''your connection is not private" page. After click advanced and proceed we are able to go to internet. If using Chrome and IE it will return securelogin.arubanetworks.com page with error. Try to update the browser to latest version but the problem still happened. We are not having issue with Smartphone device. Any idea on this?
Re: Clearpass Guest Redirection Issue
Did you install a publicly signed certificate on your controller / IAP VC?
Tim Cappalli | Aruba Security
Spoiler
Hi Cappalli,
We are install any public cert. We are using iap vc deployment over 30 sites nationwide. We are having this issue with one site only on certain windows user.
Hi Cappalli,
We are install any public cert. We are using iap vc deployment over 30 site nationwide. We are having this issue with one sites only on certain windows user.
sorry..we are not using any public cert
Hi Cappalli,
Thanks for the input. But i curios why other site also having same deployment without any public cert install but not having this problem.
Some browsers do not show the warning. Other people just click through it. You should get a public cert as soon as possible.
