Clearpass and Intel AMT
  • 1.  Clearpass and Intel AMT
    Posted Aug 23, 2017 05:09 AM
    Hi All
    Apologies if this would be better aimed at Cisco but wondering if anyone has any experience of using CPPM to provide RADIUS authentication for Intel AMT cards via MAB auth.
    We have a specific scenario where we have devices on our network that present both the normal data NIC and the AMT NIC at the same time, on initial authentication this appears fine and both show auth Authz Success on our switch, after a period of time the AMT NIC then goes to status Authz Failed.
    Config from our switch and CPPM included below, if it's worth noting we only send one Enforcement Profile back regardless of whether it's a Data NIC or the AMT NIC at the moment and the Data NIC may be 802.1x or MAB authenticated depending on the build on the device.
    Switch Port Config
    interface FastEthernet0/12
     description VLAN 2 - Auth High Security Mode
     switchport access vlan 2
     switchport mode access
     ip device tracking maximum 4
     no logging event link-status
     authentication control-direction in
     authentication event server dead action authorize vlan 2
     authentication host-mode multi-auth
     authentication order dot1x mab
     authentication priority dot1x mab
     authentication port-control auto
     authentication periodic
     authentication timer restart 0
     authentication timer reauthenticate server
     authentication timer inactivity 3600
     authentication violation restrict
     mab
     no snmp trap link-status
     dot1x pae authenticator
     dot1x timeout quiet-period 30
     dot1x timeout tx-period 5
     spanning-tree portfast
    end
    sh auth sess int fa0/12
                Interface:  FastEthernet0/12
              MAC Address:  0023.2438.c288
               IP Address:  10.201.181.12
                User-Name:  host/4990POS0002.BC.JSPLC.NET
                   Status:  Authz Success
                   Domain:  DATA
           Oper host mode:  multi-auth
         Oper control dir:  in
            Authorized By:  Authentication Server
               Vlan Group:  N/A
             Per-User ACL:  permit ip any any
          Session timeout:  43200s (server), Remaining: 18790s
           Timeout action:  Reauthenticate
             Idle timeout:  3600s (local), Remaining: 761s
        Common Session ID:  0ABDB5060000E2FDAFFFFB26
          Acct Session ID:  0x000104AD
                   Handle:  0xF6000464
    Runnable methods list:
           Method   State
           dot1x    Authc Success
           mab      Not run
              MAC Address:  0023.2438.c289
                User-Name:  00232438c289
                   Status:  Authz Failed
                   Domain:  DATA
          Session timeout:  N/A
             Idle timeout:  3600s (local), Remaining: 3083s
        Common Session ID:  0ABDB5060000E2FCAFFF8B69
          Acct Session ID:  0x0001046C
                   Handle:  0x38000463
           Method   State
           dot1x    Failed over
           mab      Authc Success
     CPPM Enforcement Profile
    Enforcement Profiles - PROFILE-WIRED-STORE-SKINNY-POS
    Summary
    Profile:
    Description:		Skinny Store POS
    Type:			RADIUS
    Action:			Accept
    Device Group List:	-
    Attributes:
     	Type		Name				Value
    1.	Radius:IETF	Session-Timeout		=	86400
    2.	Radius:IETF	Termination-Action	=	RADIUS-Request (1)
    3.	Radius:Cisco	Cisco-AVPair		=	ip:inacl#1=permit ip any any
    Matt.
  • 2.  RE: Clearpass and Intel AMT
    Posted Aug 23, 2017 09:06 AM
    Please post the failed access tracker request.
  • 3.  RE: Clearpass and Intel AMT
    Posted Aug 23, 2017 09:25 AM
    Hi Tim,
    We don't see any failed auths in CPPM, I've attached the successful entry we see below.
    Login Status:
    ACCEPT
    Session Identifier:
    R0012f2dd-15-599d7e6a
    Date and Time:
    Aug 23, 2017 14:08:58 BST
    End-Host Identifier:
    00-23-24-38-C2-89
    Username:
    00232438c289
    Access Device IP/Port:
    10.189.181.6:50012
    (JS_JS4990-0G-M-01-C296-1 / Cisco)
    System Posture Status:
    UNKNOWN (100)
    Policies Used -
    Service:
    SERVICE-WIRED-MAB-CISCO
    Authentication Method:
    MAC-AUTH
    Authentication Source:
    Local:localhost
    Authorization Source:
    [Endpoints Repository]
    Roles:
    ROLE-DEVICE-KNOWN, ROLE-LOCATION-STORE-SKINNY, ROLE-POS-STORELINE, [User Authenticated]
    Enforcement Profiles:
    Service Monitor Mode:
    Disabled
    Online Status:
    Online
