Super Contributor I
Customized Captive Portal
Hi, is possible add field in Guest Self Registration = Date
attachments image
Re: Customized Captive Portal
My question would be what would it be used for. The date is already tagged on the account when they register.
Thank You,
Troy
Super Contributor I
Sorry for not explaining well,
I need to ask for birthday
Yes you can but at the moment I'm not by a computer. I can put together a how - to later tonight.
Thank You,
Troy
Super Contributor I
Thanks Arnold,
Couple Notes. The first link is based on the old amigopod system but it is all the same except the reports. The second link includes on how to do reports. I aslo attached a PDF based on the second link.
http://www.amigopod.com/HOWTO/Survey/
If you have partner access.
https://afp.arubanetworks.com/afp/index.php/How-To:_Create_a_Self_Registration_Survey
Thank You,
Troy
Super Contributor I
Thanks very much!!!
