Failure W-ClearPass Cumulative Patch 2 for 6.6.0 and 6.6.1
Hello, I'm new here. My name is Hubert. I have 2 Clear Pass VMs. one as a Subscriber and a publisher.
I want to import the latest patch 2 for 6.6.0. However, I get the following error: ". Download is stuck or interrupted Run Check Status Now and retry."
 If I want to import the patch manually then the following error message appears: "Please Error in processing request retry ...."
I'm stuck here. What can I do?
Greeting Hubert
Re: Failure W-ClearPass Cumulative Patch 2 for 6.6.0 and 6.6.1
On the download stuck sometimes if you hit save again on the sub ID It will clear the error, or TAC can clear the error.
On you upload issues I seen issues with some browsers. Can you try a different browser?
Thank You,
Troy
Hi Tarnlod,
Hi, I have the sub id removed and stored. Subsequently, the sub id added again. It's still the same message. What is a TAC? A support call? We have support from Dell? Where can I create a TAC?
TAC is aruba/HPE support. If you are running a dell CPPM then I believe you will need to contact Dell. If you contact TAC they can tell you.
Thank You,
Troy
Hello, I was able to solve Probelm where I update to the CLI using the command "system update -i http: //meinwebserver/CPPM-x86_64-20160819-clearpass-6.6-updates-2-dell-66-patch.signed tar "have installed.
Thank you very much
