GRE Tunnel between VC Instant and Clearpass ?
  • 1.  GRE Tunnel between VC Instant and Clearpass ?
    Posted Dec 04, 2014 03:54 AM
    I know this two solutions support the GRE, and i know, it is possible to create GRE tunnel between a controler Aruba and Clearpass (example for the guest) ... but is it possible to create a GRE tunnel between a Instant VC and Clearpass, for isolate the guest to access the authentification portal ?
    Thks
    regards
    Yann
  • 2.  RE: GRE Tunnel between VC Instant and Clearpass ?
    Posted Dec 21, 2014 10:12 AM
    i believe the only tunnel IAP can setup is back to a controller, not even to other VPN devices. so no GRE either.
  • 3.  RE: GRE Tunnel between VC Instant and Clearpass ?
    Posted Dec 23, 2014 02:49 AM
    Ok thanks you boneyard
  • 4.  RE: GRE Tunnel between VC Instant and Clearpass ?
    Posted Dec 24, 2014 03:11 AM
    I think that i go to suggest of develop this feature.
