Our ClearPass Guest device registration pages seem to be good to go. In a web login page I've got
{if $smarty.server.SSL_TLS_SNI == 'mydevicesxb.york.ac.uk'}
<meta http-equiv="refresh" content="0;url=https://mydevicesxb.york.ac.uk/guest/mac_create.php">
{elseif .....
So anything using FQDN https://mydevicesxb.york.ac.uk/ gets redrected to
That's all and well, but at some point what the user sees nees to be expanded to using other mydevicesxb .... URLs, e.g. being able to modify / delete any of your registered devices. While I can set this up in ClearPass Guest, its a bit pointless if the smarty script just redirects things to ...mac_create.php
What would be the smarty code to check for
if url=https://mydevicsxb.york.ac.uk/ then .....mac_create.php
else if url:https://mydevicesxb.york.ac.uk/<some other path> then allow access to the supplied URL?
Rgds
Alex
