How many lines of ACL can be dynamically assigned to a port by ClearPass?
How many lines of ACL can be dynamically assigned to a port by radius through vendor-specific attribute VSA?
Re: How many lines of ACL can be dynamically assigned to a port by ClearPass?
Which NAD type/vendor?
Tim Cappalli | Aruba Security
Currently I am using NAD as Brocade ICX7450.
I know that Brocade ICX7450 has a limit in the device. Below link explain the limit of the Brocade device.
http://www.brocade.com/content/html/en/configuration-guide/FI_08030_SECURITY/GUID-FC540E9E-CDCF-4090-908E-69F6F6303FB5.html
But I want to know is that when ClearPass return ACL to the NAD devices, is there any limit for the number of lines in the ClearPass as well?
Regards
Ashwani Kaundal
Technical Solution Consultant
CSC Bangalore - TS Consulting
M +91-8088706486
This is not something we've tested. I've used at least 20 in a NAS-Filter-Rule in the past.
