the help states: You can use a hyphen to indicate the range of device IP addresses following the format a.b.c.d-e. For example, 192.168.1.1-20.
you might be able to work with that in the third octet although im not very sure that will work.
the alternative is with exporting, editing xml and importing devices and add more quickly like that.
