How to add onguard agent in quick connect agent while onboarding
  • 1.  How to add onguard agent in quick connect agent while onboarding
    Posted Jul 15, 2015 06:46 AM
    I want to add the  onguard agent file in quick connect agent while onboarding the dvices, SO that the onguard agent will be installed along with the quick connect agent. Where  can inculde the onguard  agent in the quick connect agent while on boarding the assets.
    Kindly help.
    PRASANTH.
  • 2.  RE: How to add onguard agent in quick connect agent while onboarding
    Posted Jul 15, 2015 07:07 AM
    You can only do this with Windows. In your provisioning configuration, you can add the OnGuard exe.
    Tim
  • 3.  RE: How to add onguard agent in quick connect agent while onboarding
    Posted Jul 15, 2015 07:32 AM
    Thanks for the quick reply, Under Provisioning Setting i did't found a option to check or include, where I need to add the onguard exe. Can you please help.
    PRASANTH.
  • 4.  RE: How to add onguard agent in quick connect agent while onboarding
    Posted Jul 15, 2015 07:38 AM
    Onboard > Configuration > Windows Applications
    Create a new app set and then select it in your configuration profile.
    Tim
  • 5.  RE: How to add onguard agent in quick connect agent while onboarding
    Posted Jul 15, 2015 07:48 AM
    Hi Pavan,
    As of now we can add "Onguard agent" only for windows through Quick connect Application. the following snapshot will help you to understand the same.
