Frequent Contributor II
I have configured clearpass and wireless controller with 802.1x wireless but there is issue?
I have configured aruba controller and clearpass server for 802.1x againest local user database the thing is that when connecting with my mobile it is asking for password only liks PSK not fro usernaem and password what may cause such a thing?
Re: I have configured clearpass and wireless controller with 802.1x wireless but there is issue?
It's possible that you have the wrong WPA2 configured on the SSID profile. You should be using WPA2-AES.
For example:
Also, make sure you have the appropriate AAA profile applied to that SSID. I wrote a doc that, though it's old, walks through the entire setup:
http://community.arubanetworks.com/t5/Community-Tribal-Knowledge-Base/TechNote-v1-3-Aruba-Wireless-and-ClearPass-6-Integration-Guide/ta-p/70714
Hope this helps.
Zach Jennings
Looks like that download link on that page isn't working. You can download it here: http://community.arubanetworks.com/aruba/attachments/aruba/tkb@tkb/220/2/Aruba%20Wireless%20and%20ClearPass%206%20Integration%20Guide%20v1.3.pdf
Zach Jennings
xcellent brother the issue was that I chooeed 802.1x/wep as I saw 802.1x so I choosed it but why they writed 802.1x iin this option?
I believe that is for dynamic WEP mode. I agree, that it is confusing.
Zach Jennings
