I need to deploy Clearpass from Scratch so I Need Documentions oragnized?
  • 1.  I need to deploy Clearpass from Scratch so I Need Documentions oragnized?
    Posted Nov 07, 2014 07:59 AM
    Plz I need to ready many documents to implement clearpass from the scratch so what is documentations should I read and kindly provide what shoud I read first ?
  • 2.  RE: I need to deploy Clearpass from Scratch so I Need Documentions oragnized?
    Posted Nov 07, 2014 08:00 AM
    You should really work with your Aruba team or a partner or take a training class. ClearPass can be difficult to deploy without any experience.
  • 3.  RE: I need to deploy Clearpass from Scratch so I Need Documentions oragnized?
    Posted Nov 07, 2014 08:04 AM
    thats why I asked fro some documents that I shoudl read before the Deployment and I will check with partner but if you can provide me with any helpfull documenst will be great
  • 4.  RE: I need to deploy Clearpass from Scratch so I Need Documentions oragnized?
  • 5.  RE: I need to deploy Clearpass from Scratch so I Need Documentions oragnized?
    Posted Nov 07, 2014 08:12 AM
    Realy Thank you you are one of the best :)
  • 6.  RE: I need to deploy Clearpass from Scratch so I Need Documentions oragnized?
    Posted Nov 07, 2014 08:14 AM
    Also be sure to check out Aruba Solutions Exchange. It can help you build out configurations.
    https://ase.arubanetworks.com/
  • 7.  RE: I need to deploy Clearpass from Scratch so I Need Documentions oragnized?
    Posted Nov 11, 2014 06:19 AM
    Hi Tim
    Can you plz give me an example of configuration workflow like what to configure first ?
