Contributor II
IAP Mac auth and 802.1x
Gang, here is my senario. I have IAPs and want to use Mac auth before 802.1x auth (NPS). I need to know step by step the settings that need to be implemented in NPS to get this to work? I have enabled mac auth in the SSID, recommendations on the delimiter setting is welcome?
I've read pieces of blog posts stating mac addresses need to reside in NPS or AD. None of those suggestings work. thxs
Re: IAP Mac auth and 802.1x
You can use MAC-authentication -OR- 802.1X with MAC authorization.
You need a policy engine like ClearPass to do the latter.
Tim Cappalli | Aruba Security
Contributor II
Isn't this article doing what I'm trying to achieve?: https://arubanetworkskb.secure.force.com/pkb/articles/HowTo/R-399
Problem is, this article is vague regarding the actual settings in NPS. Ideas?
thxs
This will not scale. It's telling you to write custom connection policies for each username/mac-address combination.
