IAP Vlans ID Mismatch
I have an IAP-325, firmware 6.4.2.6-4.1.3.0, configured to serve two SSIDs. The IAP is connected to a trunk port on a Cisco SG500 switch and there are 2 employees Vlans configured.
Cisco side we have a port for the up link to the IAP configured as:
switch port mode trunk, native Vlan = 1, Vlans allowed 1 Untagged, 2-3 Tagged.
The switch provides two DHCP pools 192.168.1.x and 192.168.2.x to serve the Vlans.
IAP has a static IP address assigned on the net 192.168.0.x (native Vlan 1 used for management purpose).
I have setup 2 SSIDs:
SSID Office, Client IP assignment - Network  assigned, Client Vlan management Static 2
SSID Sales, Client IP assignment - Network assigned, Client Vlan management Static 3
When i try to connect to the SSID Office (serving Vlan 2) it goes on DHCP timeout and the defualt DHCP address 169.254.x.x is provided (so not working), whilst when i connect to the SSID Sales (serving Vlan 3) it works well (the correct DHCP address in network 192.168.2.x is provided).
The only way i have found to make the Vlan 2 works is:
I assigned an ip address to the IAP on the 192.168.1.x (belonging to the Vlan 2)
I modified the Cisco switch port  excluding the Vlan 1 and making the Vlan 2 native (untagged). Then i modified the static assignment of the network SSID Office from Vlan 2 to Vlan 1. It is really weird, because in the Cisco trunk port Vlan 1 is not allowed (i have Vlan 2 untagged and Vlan 3 tagged), i didn't use a packet analyzer but it seems the Vlan 1 and 2 are reverted. Strange but it works.
Any idea about this weird behaviour ?
Re: IAP Vlans ID Mismatch
What is the default gateway of your clients?
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Cisco switch works on L3, so in my case i have :
Net 192.168.1.0 Def Gateway 192.168.1.1
Net 192.168.2.0 Def Gateway 192.168.2.1
What you should do, is do a dhcp debug packet dump to ensure that the client is indeed requesting dhcp packets:  https://community.arubanetworks.com/t5/Controller-less-WLANs/How-to-enable-packet-trace-to-debug-DHCP-packets-in-Instant/ta-p/179952
I did some debug on both setup.
First setup (NOT WORKING).
Cisco switch uplink port in trunk mode, Vlan 1 untagged (native), Vlan 2-3 tagged.
IAP IP address 192.168.0.5 i guess in Vlan 1 (ad by default IAP settings).
SSID Office Vlan 2 DHCP pool 192.168.1.x (assigned by Cisco switch), not working.
SSID Sales Vlan 3 DHCP pool 192.168.1.x (assigned by Cisco switch),  working.
DHCP debug info on a client (desktop) :
WIFIAD01# debug pkt mac 04:69:f8:dd:6f:1f
WIFIAD01# debug pkt match mac
WIFIAD01# debug pkt type dhcp
WIFIAD01# debug pkt dump
If source or destination MAC is 04:69:f8:dd:6f:1f
AND packet is of type DHCP
Press 'q' to quit.
Received packet from aruba101 (timestamp (116-8-11 22:31:15:184176) )
[asap_firewall_forward(5048):firewall entry] len 342, vlan 0, egress CP, ingress aruba101:
#mac: etype 0800 smac 04:69:f8:dd:6f:1f dmac ff:ff:ff:ff:ff:ff
#ip: sip 0.0.0.0, dip 255.255.255.255, proto 17, dscp 48, fragment ok, last fragment, fragment offset 0
#udp: sport 68 dport 67 len 308
#dhcp: message-type: request
hardware type: 1, len: 6, hops: 0
txn id: 0xabc2874b, seconds elapsed: 10
client mac: 04:69:f8:dd:6f:1f
magic cookie: 0x63825363
#dhcp-option: message-type: discover
[asap_firewall_forward(5218):vlan decision] len 342, vlan 2, egress CP, ingress aruba101:
[asap_firewall_check_dhcp_packet(2386):dhcp packet from client] len 342, vlan 2, egress CP, ingress aruba101:
[asap_firewall_forward(5583):looking up bridge entry] len 342, vlan 2, egress CP, ingress aruba101:
[asap_firewall_forward(5894):bridge section] len 342, vlan 2, egress CP, ingress aruba101:
[asap_firewall_forward(6023):session section] len 342, vlan 2, egress vlan 2, ingress aruba101:
[asap_firewall_forward(6217):fastpath returned 1 opcode 4] len 342, vlan 2, egress vlan 2, ingress aruba101:
[asap_firewall_forward(6249):slowpath section: opcode 4] len 342, vlan 2, egress vlan 2, ingress aruba101:
[asap_firewall_forward(6485):back to fastpath, opcode 3] len 342, vlan 2, egress vlan 2, ingress aruba101:
[asap_firewall_forward(6789):route section] len 342, vlan 2, egress vlan 2, ingress aruba101:
[asap_firewall_forward(6839):cp route section] len 342, vlan 2, egress vlan 2, ingress aruba101:
[asap_firewall_forward(7122):forward section] len 342, vlan 2, egress vlan 2, ingress aruba101:
[asap_firewall_flood(8476):flooding] len 342, vlan 2, egress vlan 2, ingress aruba101:
[asap_firewall_flood(8533):adding option 82] len 342, vlan 2, egress vlan 2, ingress aruba101:
[asap_firewall_add_rem_dhcp_option82(8125):returning w/o adding option 82] len 342, vlan 2, egress vlan 2, ingress aruba101:
[asap_firewall_add_vlan_to_dhcp(8313):adding vlan to dhcp] len 342, vlan 2, egress vlan 2, ingress aruba101:
[asap_firewall_add_vlan_to_dhcp(8354):added vlan to dhcp] len 346, vlan 2, egress vlan 2, ingress aruba101:
#udp: sport 68 dport 67 len 312
#dhcp-option: aruba-vlan: 2
[asap_firewall_flood(9208):stack section protocol=0x8ffb, type=1] len 346, vlan 2, egress vlan 2, ingress aruba101:
[asap_firewall_send_up_stack(3316):going to stack protocol:0x8ffb type:1] len 332, vlan 2, egress vlan 2, ingress br0:
Received packet from aruba101 (timestamp (116-8-11 22:31:16:242876) )
txn id: 0xabc2874b, seconds elapsed: 11
Received packet from aruba101 (timestamp (116-8-11 22:31:18:795360) )
txn id: 0xabc2874b, seconds elapsed: 13
Received packet from aruba101 (timestamp (116-8-11 22:31:23:670524) )
txn id: 0xabc2874b, seconds elapsed: 18
END OF DEBUG INFO
Second setup ( WORKING).
Cisco switch uplink port in trunk mode, Vlan 2 untagged (native), Vlan 3 tagged.
IAP IP address 192.168.1.5.
SSID Office Vlan 1 DHCP pool 192.168.1.x (assigned by Cisco switch),  working.
Press 'q' to quit.
Received packet from bond0 (timestamp (116-8-11 22:19:34:620470) )
[asap_firewall_forward(5048):firewall entry] len 286, vlan 0, egress CP, ingress bond0:
  #mac: etype 0800 smac 24:01:c7:03:72:09 dmac 04:69:f8:dd:6f:1f
  #ip: sip 192.168.1.1, dip 192.168.1.151, proto 17, dscp 56, fragment ok, last fragment, fragment offset 0
    #udp: sport 67 dport 68 len 252
      #dhcp: message-type: reply
             hardware type: 0, len: 0, hops: 0
             txn id: 0x00000000, seconds elapsed: 0
             your ip: 192.168.1.151
      #dhcp-option: message-type: nack
[asap_firewall_forward(5218):vlan decision] len 286, vlan 1, egress CP, ingress bond0:
[asap_firewall_check_dhcp_packet(2426):dhcp packet to client] len 286, vlan 1, egress CP, ingress bond0:
[asap_firewall_forward(5583):looking up bridge entry] len 286, vlan 1, egress CP, ingress bond0:
[asap_firewall_forward(5894):bridge section] len 286, vlan 1, egress CP, ingress bond0:
[asap_firewall_forward(6023):session section] len 286, vlan 1, egress vlan 1, ingress bond0:
[asap_firewall_forward(6217):fastpath returned 1 opcode 4] len 286, vlan 1, egress vlan 1, ingress bond0:
[asap_firewall_forward(6249):slowpath section: opcode 4] len 286, vlan 1, egress vlan 1, ingress bond0:
[asap_firewall_forward(6485):back to fastpath, opcode 3] len 286, vlan 1, egress vlan 1, ingress bond0:
[asap_firewall_forward(6789):route section] len 286, vlan 1, egress vlan 1, ingress bond0:
[asap_firewall_forward(6839):cp route section] len 286, vlan 1, egress vlan 1, ingress bond0:
[asap_firewall_forward(7122):forward section] len 286, vlan 1, egress vlan 1, ingress bond0:
[asap_firewall_flood(8476):flooding] len 286, vlan 1, egress vlan 1, ingress bond0:
[asap_firewall_flood(8675):checking dev8 bond0] len 286, vlan 1, egress vlan 1, ingress bond0:
[asap_firewall_flood(8675):checking dev20 aruba101] len 286, vlan 1, egress vlan 1, ingress bond0:
[asap_firewall_flood(9190):flooding to aruba101] len 286, vlan 1, egress vlan 1, ingress bond0:
[asap_firewall_flood(9208):stack section protocol=0x800, type=3] len 286, vlan 1, egress vlan 1, ingress bond0:
Press 'q' to quit.
Received packet from aruba001 (timestamp (116-8-11 22:21:31:938246) )
[asap_firewall_forward(5048):firewall entry] len 342, vlan 0, egress CP, ingress aruba001:
             txn id: 0xabc28749, seconds elapsed: 0
[asap_firewall_forward(5218):vlan decision] len 342, vlan 1, egress CP, ingress aruba001:
[asap_firewall_check_dhcp_packet(2386):dhcp packet from client] len 342, vlan 1, egress CP, ingress aruba001:
[asap_firewall_forward(5583):looking up bridge entry] len 342, vlan 1, egress CP, ingress aruba001:
[asap_firewall_forward(5894):bridge section] len 342, vlan 1, egress CP, ingress aruba001:
[asap_firewall_forward(6023):session section] len 342, vlan 1, egress vlan 1, ingress aruba001:
[asap_firewall_forward(6217):fastpath returned 1 opcode 4] len 342, vlan 1, egress vlan 1, ingress aruba001:
[asap_firewall_forward(6249):slowpath section: opcode 4] len 342, vlan 1, egress vlan 1, ingress aruba001:
[asap_firewall_forward(6485):back to fastpath, opcode 3] len 342, vlan 1, egress vlan 1, ingress aruba001:
[asap_firewall_forward(6789):route section] len 342, vlan 1, egress vlan 1, ingress aruba001:
[asap_firewall_forward(6839):cp route section] len 342, vlan 1, egress vlan 1, ingress aruba001:
[asap_firewall_forward(7122):forward section] len 342, vlan 1, egress vlan 1, ingress aruba001:
[asap_firewall_flood(8476):flooding] len 342, vlan 1, egress vlan 1, ingress aruba001:
[asap_firewall_flood(8675):checking dev8 bond0] len 342, vlan 1, egress vlan 1, ingress aruba001:
[asap_firewall_flood(9190):flooding to bond0] len 342, vlan 1, egress vlan 1, ingress aruba001:
[asap_firewall_flood(8675):checking dev19 aruba001] len 342, vlan 1, egress vlan 1, ingress aruba001:
[asap_firewall_flood(8675):checking dev20 aruba101] len 342, vlan 1, egress vlan 1, ingress aruba001:
[asap_firewall_flood(9208):stack section protocol=0x800, type=1] len 342, vlan 1, egress vlan 1, ingress aruba001:
Received packet from bond0 (timestamp (116-8-11 22:21:31:941370) )
[asap_firewall_forward(5048):firewall entry] len 351, vlan 0, egress CP, ingress bond0:
    #udp: sport 67 dport 68 len 317
      #dhcp-option: netmask: 255.255.255.0
      #dhcp-option: router: 192.168.1.1
      #dhcp-option: dns-server: 192.168.1.22
      #dhcp-option: dns-name: xxxxxxxx
      #dhcp-option: message-type: offer
      #dhcp-option: dhcp-server: 192.168.1.1
[asap_firewall_forward(5218):vlan decision] len 351, vlan 1, egress CP, ingress bond0:
[asap_firewall_check_dhcp_packet(2426):dhcp packet to client] len 351, vlan 1, egress CP, ingress bond0:
[asap_firewall_forward(5583):looking up bridge entry] len 351, vlan 1, egress CP, ingress bond0:
[asap_firewall_forward(5894):bridge section] len 351, vlan 1, egress CP, ingress bond0:
[asap_firewall_forward(6023):session section] len 351, vlan 1, egress aruba001, ingress bond0:
[asap_firewall_forward(6217):fastpath returned 1 opcode 4] len 351, vlan 1, egress aruba001, ingress bond0:
[asap_firewall_forward(6249):slowpath section: opcode 4] len 351, vlan 1, egress aruba001, ingress bond0:
[asap_firewall_forward(6485):back to fastpath, opcode 3] len 351, vlan 1, egress aruba001, ingress bond0:
[asap_firewall_forward(6789):route section] len 351, vlan 1, egress aruba001, ingress bond0:
[asap_firewall_forward(6839):cp route section] len 351, vlan 1, egress aruba001, ingress bond0:
[asap_firewall_forward(7122):forward section] len 351, vlan 1, egress aruba001, ingress bond0:
[asap_firewall_forward(7439):forwarding packet to aruba001] len 351, vlan 1, egress aruba001, ingress aruba001:
Received packet from aruba001 (timestamp (116-8-11 22:21:32:955272) )
             txn id: 0xabc28749, seconds elapsed: 1
      #dhcp-option: requested-ip: 192.168.1.151
      #dhcp-option: message-type: request
Received packet from bond0 (timestamp (116-8-11 22:21:32:957771) )
      #dhcp-option: message-type: ack
[asap_firewall_check_dhcp_packet(2467):Send dhcp user(192.168.1.151) to STM and create the L3 user] len 351, vlan 1, egress CP, ingress bond0:
[asap_firewall_check_dhcp_packet(2484):Created L3 user] len 351, vlan 1, egress CP, ingress bond0:
END OF DEBUG INFO
I noticed that in the first case (not working) the received packets are on "aruba101" interface and in the second one (working) the received packets are on "bond0" interface.
Any idea ?
